Navigation Pane selection with shortcuts
laguna92651
I would like to set up a set of shortcuts on my task bar that will open the Mail, Calendar or Task pane in Outlook 2013. Outlook will already be running, I just want to be able switch between panes with a single click.
Forum Admin
Create shortcuts using command lines in this format-
"C:\Program Files\Microsoft Office 15\root\office15\outlook.exe" /select outlook:calendar
in some cases you can use just outlook or outlook.exe - i think the new shortcut command needs the full path. If it opens a new window, try adding the /recycle switch.
outlook /select "outlook:Inbox"
More information: http://www.slipstick.com/outlook/2013/command-lines-for-outlook-2013/
If outlook is in focus, use the buttons at the bottom of the navigation pane or click the folder names in the folder bar under the navigation pane. Ctrl+n shortcuts also switch modules - 1,2,3,4,5,7,8
laguna92651
The switches work fine, thanks. The Outlook shortcuts I added show an "x" instead of the the normal shortcut arrow. What does the "x" signify?
Command that I used.
"C:\Program Files\Microsoft Office 15\root\office15\OUTLOOK.EXE" /select outlook:tasks /recycle
The icon seems to sometimes switch to the following, with a different icon.
Diane Poremsky Outlook's Folder Navigation Pane Disappears New Slipstick.com Articles 2
D Mail accounts don't show up in navigation pane Using Outlook 1
T Unexpected change of the order of the folders in my navigation pane Using Outlook 6
T Occasionally, no vertical scroll bar in navigation pane in Outlook 2013 Using Outlook 9
K bcm not showing in outlook 2013 navigation pane BCM (Business Contact Manager) 3
D Views with the ToDo Bar and Navigation Pane Using Outlook 1
J How To Change Font Size For Folder Names on Navigation Pane in Outlook 2013 Using Outlook 1
L Navigation Pane Using Outlook 2
N Backing Up Navigation Pane Customizations - WinXP Using Outlook 11
G navigation pane wishlist Outlook Wishlist 0
J Add Option to remove "Links" area form Navigation Pane Outlook Wishlist 3
A BCM is not in the navigation line BCM (Business Contact Manager) 2
O Outlook 2013 not holding bottom navigation settings Using Outlook 10
M Calendar navigation displays previous field records.check calendar is shared.. Using Outlook 3
M Add small calendar to navigation Using Outlook 1
C Configuring Navigation shortcuts Using Outlook 3
B Outlook 365 - Folder pane list clears Using Outlook 26
R Folder pane width change Using Outlook 62
N Wide Line Spacing in Folder pane 2016 Using Outlook 18
GregS What controls content of Folder Pane? Using Outlook 1
A Outlook 2016 Will Not Show Any Data In the People Pane Using Outlook 17
evdbogaard How to dock the Styles Task Pane in the e-mail editing window? Outlook VBA and Custom Forms 1
N Outlook People Pane - Sent Mail Using Outlook 1
W Showing more months in the Calendar nav pane Using Outlook 10
H What Controls what is shown in the preview pane Outlook VBA and Custom Forms 1
E Reading Pane has disappeared Using Outlook 1
Diane Poremsky Excel Files Won't Display in Reading Pane New Slipstick.com Articles 1
