How to remove forms from Organizational forms library
Sandys
Exchange Server 2013
I'm using Exchange 2013 with Outlook 2010 32-bit. I have created the Organizational Forms library according to the items I found on this site. I originally gave myself -AccessRights CreateItems then tried -AccessRights ReadItems, not knowing if I needed both. It told me existing entry already existed. I was unable to see the Organizational Forms Library so I kept trying different things. I created several forms during my testing phase. I eventually figured out how to remove my permissions then made myself Owner. After that I was able to see the Library.
Now I have several forms I would like to remove. When I go to Forms Manager I can see my 3 forms under Organization Forms. If I click on them I can't Copy, Update, Delete or Properties. They are grayed out. If I click on Set, I use the Forms Library - Organization Library choice.
This seems to be a great resource for this subject.
Sandy
Sandys
No suggestions? I was hoping for at least some PowerShell commands I could try.
RMKJDE
Outlook 2013 32 bit
If you ever got an anwser or found a solution, I'd appreciate it if you could share it.
R How to remove Published forms? Outlook VBA and Custom Forms 1
P [SOLVED] Auto remove [EXTERNAL] from subject Using Outlook 14
B Remove Subject Residual Outlook VBA and Custom Forms 3
R Chancing / remove “ something ” in the subject, online archive Outlook VBA and Custom Forms 8
Morgan Fowler Remove Signature Using Outlook 1
M VBA to remove deferred delivery on a MeetingItem Outlook VBA and Custom Forms 2
J Remove extra line above signature in reply Outlook VBA and Custom Forms 5
Diane Poremsky How to Remove RSS Support from Outlook New Slipstick.com Articles 0
Diane Poremsky Remove Attachments From Messages New Slipstick.com Articles 0
Diane Poremsky Remove Office 2013 Update Banner New Slipstick.com Articles 0
O Remove duplicate mail items Outlook VBA and Custom Forms 6
Diane Poremsky Remove a password from an Outlook *.pst File New Slipstick.com Articles 3
L Fake reminder apperaring (not in calendar) - how to remove? Using Outlook 5
J Your IMAP server wants to alert you to the following: cannot remove system folder Using Outlook 3
C how to remove icons on right hand side outlook 2013 Using Outlook 2
K Remove Manage APPS button for users Exchange Server Administration 1
P Remove name and parenthses from email Using Outlook 1
G Outlook calendar entry corrupted. Constant pop up when you open outlook. Unable to delete or remove. Using Outlook 2
Diane Poremsky How to remove the primary account from Outlook 2010/2013 New Slipstick.com Articles 0
Diane Poremsky Remove an Address from Reply All New Slipstick.com Articles 0
Diane Poremsky Remove Outlook apps from Outlook New Slipstick.com Articles 0
2 Task has a strike through but is not complete - how to remove? Using Outlook 1
W URGENT Cancel and remove imported pop3 mails Using Outlook 6
T How to remove annoying Big Blue Type at beginning of my messages Using Outlook 2
H Cannot remove unwanted fields from form Outlook VBA and Custom Forms 9
T How to remove "automatically delete messages form this sender"? Using Outlook 1
M How to remove duplicate history items BCM (Business Contact Manager) 7
D Isn't there an easy way to remove duplicate contacts in outlook? Using Outlook 1
Britonius Exchange Powershell to Remove Reviewer access from all Folders in a mailbox? Using Outlook 3
