No scrolling in note field of contact record
UUU
Outlook 2013 64 bit
Hopefully this has not been addressed in another thread. (I searched for it but could not find a similar thread).
Problem:
Using Outlook 2013 on Win 8.1 computer.
When I open a Contact record and the "Notes" field has more than a few lines of text in it, I cannot scroll all the way to the bottom of that note field using the scroll bar or by using the down-arrow key within the text. That means I cannot access text below the point where the scroll bar no longer functions. To see information there, I must "control A" and "control C" to copy the full text of the note field into the computer buffer, then "control V" (paste) into Notepad in order to see all of the previously in-viewable text.
This is VERY frustrating. I didn't have this issue on my old Win7 laptop running Outlook 2010.
Suggestions welcome! Thanks!
That's related to your other problem - no scroll bars on the form itself. Try adding, oh, 10 returns or so at the end of the note. It should scroll enough for you to see the full note. (Too bad it won't help the address field. :))
Rupert Dragwater Scrolling through Directories hesitates Using Outlook 1
B Spacebar Not Scrolling Down Using Outlook 4
J Scrolling in a email message Using Outlook 1
W Get a "New Note" icon onto the QAT Using Outlook 3
D IMP.Note Versus REPORt.IPM.NOte Outlook VBA and Custom Forms 3
M One Note as a mail folder Using Outlook 6
mrje1 Note Field (Any way to do incell editing) Using Outlook 7
L Contact Photo For Calendar Note Field Using Outlook 4
L Contact Photo For Calendar Note Field Using Outlook 0
L How to acess the note field in contact item Outlook VBA and Custom Forms 19
L Outlook 2007 Code for Note Fields of Appointment Using Outlook 102
L Outlook 2007 Contact Form - Note Fields Using Outlook 25
W Calendar Note Font Reverting Using Outlook 11
M Unable to search Note section in Contacts in icloud Using Outlook 7
L Source Name for Appointment Note/Message field Using Outlook 0
J add note to body or notes Outlook VBA and Custom Forms 5
0 Add a date stamp to the note field of a custom form Outlook VBA and Custom Forms 1
S Note: The GMT offset above does not reflect daylight saving time adjustments Using Outlook 12
A Note field on general tab BCM (Business Contact Manager) 5
C Automatically Insert Recipient Name from To Field Outlook VBA and Custom Forms 4
O Filter-Query Builder-Description - what field name to use? Using Outlook 4
V Checking for empty field Outlook VBA and Custom Forms 2
A new labeled phone field Using Outlook 4
V Making a Date field mandatory in outlook form Outlook VBA and Custom Forms 2
