a general question regarding data files
Dave Horne
Outlook 2013 32 bit
My pst and ost files are located in Documents\Outlook ...
I if were to copy those files, take them with me, and place them (after moving his files) in the same folder on his computer, could I use his version of Outlook 2013 while I'm staying with him?
(I realize this is why IMAP is preferred, but my setup is POP). Is all my information located in those files?
Thanks in advance, Dave Horne
latitudeit
Outlook 2013 64 bit
Its not quite so simple. If I understand you correctly you just want to view your emails, or do you expect to receive and send new emails as well? You are correct all the data (emails, contacts) are stored in these files. You would be better creating a new outlook profile on the 'temporary' machine and connecting your files to this profile. You can create a new profile under 'mail' in control panel. This way when you start outlook it will ask which profile you want to use and you can leave the existing profile untouched!
Dave Horne
Outlook 2013 32 bit
OK, thanks. I assume when you said 'profile', that's just the settings for me to be able to send and receive e-mails to my IP, right? That's not a problem for me to set up.
Dave Horne
Outlook 2013 32 bit
(A correction to my initial message, all the files in question are pst files, I mentioned ost. Just being accurate.)
F General Question Using Outlook 0
F 'General failure (URL) Server execution failed' Using Outlook 1
R Force use of general outbox Using Outlook 1
1 Controlling Outlook Setting not in general GPO Templates Using Outlook 2
C General availability of Personal Archives in Outlook 2007 Using Outlook 3
A General, how to get started? [kwrds begin start newbie] Outlook VBA and Custom Forms 3
A Note field on general tab BCM (Business Contact Manager) 5
D.Moore SendAndReceive question Outlook VBA and Custom Forms 2
N Question Using Outlook 8
CWM030 Email Catagorties question Using Outlook 1
MahdeeyaAbdulla Friend's outlook question Using Outlook 1
rerun101 Question about message options Outlook VBA and Custom Forms 4
M Question: Is there a rule that will save email in Windows Explorer Outlook VBA and Custom Forms 3
M Question on address book Using Outlook 1
V Question on pop email Using Outlook 2
R Outlook 2007 - Email Question - POP3 to IMAP Outlook VBA and Custom Forms 11
adaminaus Quick question if i may Using Outlook 4
T Business Projects question BCM (Business Contact Manager) 0
V question about personal and shared calendars Exchange Server Administration 1
C Custom Forms: Question about retaining form information throughout the entire conversation Outlook VBA and Custom Forms 2
D OST question Exchange Server Administration 5
V iCloud question Using Outlook 3
J "Specific word in body" question Using Outlook 1
A Newb-ish question Using Outlook 2
A The hardest VBA/Outlook question yet Using Outlook 1
S DAG question Exchange Server Administration 0
P Outlook File Extension Question Using Outlook 3
J Outlook 2010 Calendaring Question Using Outlook 0
K Syncing outlook with iCloud question Using Outlook 5
T Outlook Prf/Automation question Using Outlook 2
T Settings question Using Outlook 6
D Question re: Grouping by Due Date vs. Sorting by Due Date Using Outlook 1
IGWright Outlook 2013 .pst Question Using Outlook 10
F To Do Bar question Using Outlook 1
T I recently changed my pop3 email to an imap - question on folders Using Outlook 3
e_a_g_l_e_p_i Can someone please answer a question about tasks for me Using Outlook 2
