Default inbox not automatically sending/receiving
Tony_015
Outlook 2013 64 bit
Hi there. I have four IMAP email accounts, all of which are in my Send/Receive Groups list. Three of these accounts are doing their send/receive as scheduled, however my default account seems to only update when I manually select the relevant inbox and click 'Update Folder'. So, for three accounts I get scheduled updates, but for the default account I need to do it manually.
Any idea why this is or what I need to do to fix it? Alternatively, a VBA code to select the specific folder and force the update would be an acceptable workaround; I would park the code in 'ThisOutlookSession' and create a button for it in the ribbon.
Any help or advice would be appreciated!
Forum Admin
Try splitting the Send and Receive groups into 2 groups and see if it syncs better. Set one group to check two accounts every 5 minutes and the second group to check the other two every 9 minutes. (You can use higher numbers but should use two different odd numbers so the S&R doesn't overlap.)
O How come default profile changed? Using Outlook 2
T Outlook changes default account Using Outlook 1
V VBA when replying + Default Account Using Outlook 2
P Outlook.com account overrules default account Using Outlook.com accounts in Outlook 8
P Outlook 2016 Not Default Client Using Outlook 5
D Add all meeting rooms to the meeting request by default Outlook VBA and Custom Forms 0
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 5
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 0
N How to delete default folder "Contacts" (olFolderContacts) in a .pst file Using Outlook 8
D Default Send Account that Works? Using Outlook 0
T Changing default Mail Account in Outlook 2016 - POP3 Using Outlook 1
J Setting default address book Using Outlook 0
C Change default colors for conditional formatting Using Outlook 2
S Default Font in body of Task Using Outlook 0
Diane Poremsky Set Another Data File as Default When Using an Exchange Account New Slipstick.com Articles 0
Diane Poremsky Shared Mailboxes and the Default 'Send From' Account New Slipstick.com Articles 0
Diane Poremsky Working with VBA and non-default Outlook Folders New Slipstick.com Articles 0
Diane Poremsky To Change the Default E-mail Program in Windows New Slipstick.com Articles 0
C Delete Subject-Add Organizer to all Reservations in Default Calendar. Using Outlook 0
Diane Poremsky Setting the default Country for Outlook Contacts New Slipstick.com Articles 0
B Outlook 2016: Can't delete default calendar but I don't use it Using Outlook 7
B Calendar shows too much info by default Using Outlook 0
M Default Calendar Using Outlook 0
L Change default from english to danish ...... Using Outlook 5
R Making Outlook default client in share charm Using Outlook 4
Diane Poremsky Changing the default *.pst and *.ost sizes New Slipstick.com Articles 0
E Outlook 2016 Default Blue Color Using Outlook 3
C Outlook 2016 - converting Word VBA to default Outlook message Outlook VBA and Custom Forms 0
J Installed Outlook but Default Calendar is Blank Using Outlook 3
