Outlook Backup help needed ASAP
Me Again
Outlook 2007
Hi everybody!
I am moving in less than a week and I desperately need to back up my Outlook to an external drive because my desktop computer is going on the moving van. I added the Outlook backup add-in today, but it is not working. I have it set (under options) to save to K:\Outlook\outlook backup.pst When I exit Outlook, I get this message: The J:\Outlook\folder does not exist. The file might have been moved or deleted. Do you want to create it?
How can I get it to stop looking for a J drive? I don't have anything in my J drive, so even if I choose yes to create it, it is unable to create the Outlook folder and the system cannot find the path specified.
Steps I have tried so far, which have failed:
1. Reboot the computer
2. Disable and re-enable add-ins
3. Delete and re-install the add-in
4. Try saving to a different external drive
Try opening a new message and pretend to add a file from the K folder. No idea if it will work... I'd locate the pst files and copy them you the drive (close outlook before copying). You have Outlook 2007, so the default is under localappdata. Go to File, Data File Management and select the data file then click the button to open the file location. This opens windows explorer with that pst selected. Close Outlook, wait a couple of minutes then copy the data files.
Me Again
Outlook 2007
Thank you, Diane. I am successfully able to add a file from my K drive to an email. Yesterday I did just what you recommend. I closed Outlook and manually copied my personal and archive pst over to my K drive and re-named them backup. I am bummed that Outlook's backup process doesn't work. It would be nice to have automatic backups every 7 days.
L Restoring Outlook from backup of OST Using Outlook 5
S Is it possible to backup Outlook.com/Outlook 2013 Email & Calendar info? Using Outlook.com accounts in Outlook 3
C Password for backup of Outlook Using Outlook 1
V Outlook Data File (PST) - Auto Backup Solution Using Outlook 3
B importing Outlook from a backup on an external hard drive Using Outlook 5
T Using Outlook 2010 in Outlook2003 as backup ? Using Outlook 21
D Outlook 2010 .pst file backup Using Outlook 2
R What to backup before removing Outlook 2010? Using Outlook 4
E Disappointed in Outlook 2007, backup, restore, synch Using Outlook 5
R How to backup contacts in Outlook 2010 as business cards Using Outlook 1
E Outlook 2007 backup and restore function Using Outlook 2
L Outlook backup tool Using Outlook 5
M Backup Outlook Data File BCM (Business Contact Manager) 2
e_a_g_l_e_p_i Gmail in Outlook 2010 preview issue Using Outlook 0
I Outlook is stuck at "Updating Calendar" Using Outlook 1
AmonRa Outlook 365 calendar - too much white space Using Outlook 0
C-S-R How to clear an Outlook (To Do) Task Flag? Using Outlook 8
N How do I make Outlook autocomplete addresses from a list of recognised <full_names> only? Using Outlook 2
P Outlook 2019 UI changes after 20H2 update Using Outlook 1
T The Linked Image Cannot Be Displayed in Outlook Using Outlook 5
A OutLook For Mac 16.46 Comes Up In Small Window When Opening Using Outlook 4
T Outlook creating unwanted tasks in Tasks and Todo from emails Using Outlook 1
Horsepower Moving emails between folder Outlook for Mac Outlook Wishlist 8
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
B Outlook 2016 Outlook crashes when trying to print certain emails Using Outlook 5
T Outlook Template - textbox visible based on combobox selection Using Outlook 1
P i-Phone 6s Plus receiving 2 notifications from Outlook email Using Outlook 1
C WARNING - DO NOT USE AN OUTLOOK.COM ADDRESS FOR GOOGLE ACCOUNT RECOVERY EMAIL Using Outlook 10
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
R Why doesn't outlook use "Normal" style for new messages? Using Outlook 4
