Outlook Task Will not open.
Gareth
Outlook 2013 64 bit
I use Office 365 Outlook specifically for assigning tasks (version 15.0.4659.1001). My wife who runs on the same system cannot open the task I send to her. The error message reads: " Sorry we are having trouble opening this item. This could be temporary, but if you see it again you might want to restart outlook. Outlook cannot perform this action on this type of attachment."
Additionally you cannot even delete the assigned task.
I have tried re-installing outlook on her Lenovo Laptop but this did not help.
If I send tasks to other users I don't experience the same problems.
Please can you help........
Gareth
Outlook 2013 64 bit
Hi Diane. Thank you so much for responding ! My wife is using one of the 5 licenses given on the Office 365 Home Premium, which means she is on the same version as I am on (version 15.0.4659.1001). Yes the people who can use it successfully are using the same account type. Could it be an error with the permissions ? Regards Gareth
Forum Admin
I'm thinking it's getting munged by the email server or antivirus scanner. What antivirus are you using? Does it work in Safe mode? AVG has been know to cause problems like this.
Gareth
Outlook 2013 64 bit
Thank you for the response. We are using AVG. I haven't tried the safe mode start up as yet. Perhaps I should disable AVG on my wife's system and try sending a task to her to see if it will open. What do you think.... ?
umar
Outlook 2013 64 bit
Same case, my boss is assigning me tasks but I cant respond due to same issue. please help! did you get it resolved or not?
J Outlook doesn't close. Cannot open outlook without going to task manager Using Outlook 1
K outlook workflow: automated task generation Outlook VBA and Custom Forms 4
I Collecting mail address from GAB and adding to Outlook Task Using Outlook 2
D Outlook task insert Outlook VBA and Custom Forms 3
O How to display multi-line task in To-Do List - Outlook 2010 Using Outlook 1
P Task form created in outlook 2007 Outlook VBA and Custom Forms 2
M Adding fields to Task in Outlook Home and Business 2010 Outlook VBA and Custom Forms 7
P VBA Outlook Task determination Outlook VBA and Custom Forms 2
santheocles Issue in Outlook 2013 - cannot reschedule single task Using Outlook 0
S Outlook 2010 task - comments missing Outlook VBA and Custom Forms 0
V Deafault Task Folder --> Outlook.com tasks folder Using Outlook.com accounts in Outlook 3
W Outlook 2010 Task bar issues. Using Outlook 8
Wotme Creating a Outlook task in Excel Using Outlook 7
L Outlook 2007 Contact in a Task Using Outlook 15
L Outlook 2007 E-Mail From Selected Task Using Outlook 18
P accessing custom task pane with Outlook ActiveInspector Using Outlook 1
T Outlook Task assignment acceptance Using Outlook 0
C outlook 2013 task reminders vs. outlook.com task reminders Using Outlook.com accounts in Outlook 8
F Outlook 2010 custom font style duplicates itself every time I save a task Using Outlook 0
S Outlook 2013 To Do Task does not minimize. Using Outlook 0
F Combine Outlook Task Folders into one View (Outlook 2013) Using Outlook 3
K Starting Outlook 2013 x64 minimized in Win 8 with or without Task manager Using Outlook 5
D Icloud Outlook 2010 Task/Reminder Search Problem Using Outlook 1
D Outlook 2010 - Pattern for updating task owner in generic mailbox Using Outlook 2
L Outlook 2007 New Task Folder Using Outlook 1
L Outlook 2007 Task Using Outlook 130
G iCloud task folder not showing in outlook calendar page Using Outlook 3
S Recurring Task / Delayed Email in Outlook 2010 Outlook Wishlist 10
S Outlook to validate task form before sending Using Outlook 5
M Outlook 2010 task line printing Using Outlook 1
S How to send an OUTLOOK task to a contact out of my active directory? Using Outlook 2
S Outlook Task Using Outlook 0
C Permissions in Shared Task Folders (Outlook 2010) Using Outlook 1
R Outlook 2007 task issues Using Outlook 2
J Create new outlook task into task subfolder using vba Using Outlook 6
O Assigning a single instance of a recurring task OUTLOOK 2010 Using Outlook 3
D Task and Event View in Outlook 2010? Using Outlook 3
D Inserting check boxes in task requests Outlook 2007 Using Outlook 2
C Does Microsoft Office 2011 for Mac sync the Task function in Outlook to an Iphone? Using Outlook 1
D How do I move between fields/columns in Outlook Task To-Do List view using arrow keys? Using Outlook 1
D Outlook Form Needs to move P2 to the Task Pane Using Outlook 2
V Launching Access export from Outlook task, Access Password pop-up window gets lost Using Outlook 1
A Outlook 2010 trying to create calendar/task entries generates error "Could not save item.The connect Using Outlook 2
A Outlook 2010 trying to create calendar/task entries generates error "Could not save item.The connect Using Outlook 1
S Can't delete task in Outlook 2010 Using Outlook 2
J Re: Outlook 2010: The task list is empty in the to do bar but there are many tasks there. Using Outlook 4
O How can I set up outlook to give me a popup of an appointment or task that will popup on booting up or will popup whatever I am doing when the appoint Using Outlook 1
P Outlook folder path changing automatically when move or delete Item from custom task folder which is installed in Exchange 2010 sared mailbox Using Outlook 1
