Problems with Outlook Connector in Outlook 2010
annanna
I have this problem from weeks, but I'm not able to find e fix in the web.
These the errors:
(0x80041003) Unable to connect to Windows Live Calendar
(0x8004102A) Error synchronizing your folder hierarchy. Error: 80041003
And this the last report:
HTML:
11:48:01 Programma di sincronizzazione versione 14.0.6123
11:48:01 Sincronizzazione cassetta postale "xxxxxxxxx@hotmail.it"
11:48:01 Sincronizzazione gerarchia in corso
11:48:01    1 cartella/e aggiornata/e nell'archivio online
11:48:05 Impossibile stabilire una connessione al Calendario di Windows Live.
11:48:05
11:48:05
*Request*
11:48:05 11:48:01:0475
11:48:05 GET
11:48:05  http://
11:48:05 sse.bay02.calendar.live.com
11:48:05 /calendar/sync/feedall.sse?ver=2.0&appid=0259bbef-09a7-470a-9a22-237a599e26ef&ts 14-11-18T10:22:40Z
11:48:05
11:48:05 X-HTTP-Method-Override: PUT
Cookie: WLSSC=t=EgCBAQMAAAAEgAAAC4AAIY8nULWX8tbEwQyZZ8Z0kDGsWuSHDzEclHjuoowVFLnDYEb9r0zP3FPJAm10v2xSwSPPOKbIQUdweFdbrSYccGsjTQ5kvKqmiM4xDYW/Vbw3ZnnUgKRq39YhG8y78D9erA3Wte1cZ%2bw2EOuPrKel9s0naObmxo/R170WIxIbk4fwAGQA8AD9vwYAVHOsnegda1ToHWtUECcAAAoRoAABFwBhbm5hbGFuY2luaUBob3RtYWlsLml0AFEAABZhbm5hbGFuY2luaUBob3RtYWlsLml0AAABW0lUAAUyNTA0NgCW4GQEEAIAAHqGZkAABEMABEFubmEAB0xhbmNpbmkFDgABRQAAAAAAAAAAAABwCrFD3FOeZQAA6B1rVOjE4VQAAAAAAAAAAAAAAAAOADc5LjQwLjEwMC4yNDUABQIAAAAAAAAAAAA
11:48:05
*Response*
11:48:05 11:48:05:0673
11:48:05 HTTP/1.1 500 Errore interno del server
Cache-Control: private
Content-Type: multipart/related; boundary=_9e67417c-4431-4782-bbc1-b3d938c03023_; charset=utf-8
Expires: Tue, 18 Nov 2014 11:03:03 GMT
Last-Modified: Tue, 18 Nov 2014 10:22:40 GMT
Server: Microsoft-IIS/7.5
Set-Cookie: RPSMaybe=; domain=.live.com; expires=Thu, 30-Oct-1980 16:00:00 GMT; path=/
Set-Cookie: CCN=bay02.calendar.live.com|57|0|3; doma
11:48:05
11:48:05
--_9e67417c-4431-4782-bbc1-b3d938c03023_
Content-Type: text/xml
<?xml version="1.0" encoding="utf-8"?>
<feed xmlns:sx="http://www.microsoft.com/schemas/sse" xmlns:sc="http://calendar.live.com/schemas/sync/directory" xmlns="http://www.w3.org/2005/Atom">
  <title>Hotmail Calendar Sync Directory Feed</title>
  <subtitle>The file is used for Hotmail Calendar SSE Synchronization, which lists all the user’s calendars along with the general settings</subtitle>
  <link rel="self" href
11:48:05
11:48:05 Errore di sincronizzazione.
11:48:05 Chiave di sincronizzazione insieme cartelle: 0{4d90e2e8-b440-43f3-aa0c-1545c4e4604c}1
11:48:05 Chiave di sincronizzazione insieme messaggi: 0{c7b912b5-575c-40e1-be95-ec0b35a4fc81}3
11:48:06 Errore durante l'invio o la ricezione.
11:48:06 Errore durante la sincronizzazione della gerarchia di cartelle. Errore: 80041003.
11:48:06 Sincronizzazione delle modifiche del server nella cartella "Calendario di Anna" in corso
11:48:06 Sincronizzazione delle modifiche del server nella cartella "Contatti" in corso
11:48:07
11:48:07
*Request*
11:48:07 11:48:06:0283
11:48:07 POST
11:48:07  http://
11:48:07 contacts.msn.com
11:48:07 /ABService/ABService.asmx
11:48:07
11:48:07 <ABFindAll xmlns="http://www.msn.com/webservices/AddressBook"> <abId>00000000-0000-0000-0000-000000000000</abId><abView>Full</abView><lastChange>2014-11-18T01:44:54.723-08:00</lastChange><deltasOnly>true</deltasOnly></ABFindAll>
11:48:07
*Response*
11:48:07 11:48:07:0143
11:48:07 HTTP/1.1 200 OK
Cache-Control: private, max-age=0
Content-Length: 517
Content-Type: text/xml; charset=utf-8
Content-Encoding: gzip
X-MSNSERVER: BLUCDP2031006
X-Content-Type-Options: nosniff
X-AspNet-Version: 4.0.30319
Date: Tue, 18 Nov 2014 10:48:05 GMT
11:48:07
11:48:07 <?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Header><ServiceHeader xmlns="http://www.msn.com/webservices/AddressBook"><Version>18.10.4058.1104</Version><CacheKey>14r2;a3D3B5q8ECIQbcY7iUj5bW/UYpnA01tM9Mq1X2bbcx74FPLPdtEULLc/GbvgXhBUUprjGrsyZXA6L6H8QiTHXWIQ4MY6zgOXyVKvsQGCn46nuFEg46knOY+VCSaz1CmBlZxeL1Tr2P2THkrW9s1VARoV3aYGJHZvRbvybCk
11:48:07
11:48:07 Sincronizzazione delle modifiche del server nella cartella "Bozze" in corso
11:48:07 Sincronizzazione delle modifiche del server nella cartella "Posta in arrivo" in corso
11:48:07 Sincronizzazione delle modifiche del server nella cartella "Posta eliminata" in corso
11:48:07 Sincronizzazione delle modifiche del server nella cartella "Posta indesiderata" in corso
11:48:07 Sincronizzazione delle modifiche del server nella cartella "Posta inviata" in corso
11:48:07 OK
Could anyone help me?
Thanks in advance!
Anna
annanna
In Control panel, Internet settings, look on the connection tab, lan settings button - is use proxy server enabled? if you aren't using a proxy server, uncheck the option.
Hi Diane, thanks for your answer. Unfortunately the option is already unchecked. Any other suggestions?
P Encoding problems after synchronization with Outlook Connector Using Outlook.com accounts in Outlook 6
E Outlook Connector 14 Problems Using Outlook 15
V Outlook 2016 Outlook-2016 and iCloud for Windows - Problems Using Outlook 2
P outlook.com problems Using Outlook 0
D Outlook and Icloud problems Using Outlook 0
E Outlook 2010 network printing problems Using Outlook 4
J problems with viewing aol emails in Outlook Using Outlook 3
B Problems with outlook calendar and android phone syncing calendars Using Outlook.com accounts in Outlook 1
P Sync Problems Outlook with iPad 2 Using Outlook 3
C migrating from Windows Live Mail over to Outlook 2010 Problems ... Using Outlook 2
J Outlook 2010 and Icloud multiple calenders problems. Using Outlook 10
T Outlook 2007 - iTunes - iCloud Sync Problems Using Outlook 7
S Public FolderEmail Sort Problems Outlook 2010/Migration from 2003 SBS to 2011S Using Outlook 3
S Outlook 2010 and certificate problems Using Outlook 9
M Several Problems using Outlook Using Outlook 3
W Outlook exp. 2007 problems - won't receive new mail Using Outlook 1
P Printing problems with MS Outlook 2000 Using Outlook 1
A Two strange calender problems in Outlook 2003 ... Using Outlook 2
T Outlook 2007 shut down problems Using Outlook 1
W Upgraded to Outlook 2010, now contacts have problems displaying and other issues. Using Outlook 3
G Anyone had problems using OLF.Items.Count with Outlook 2010? Using Outlook 1
L Problems with Not Responding Message in Outlook 2007 Windows 7 64 bit Using Outlook 1
G Problems with Outlook interfacing with gmail account Using Outlook 3
M Outlook 2007 Copy-Paste problems Using Outlook 6
R No problems for about three months and the, about two weeks ago I was no longer able to receive emails in Outlook. Using Outlook 4
C Outlook 2010 with BCM - Database Connection problems using Windows 7 Clients Using Outlook 1
