forward email with attachment using .oft
dwebbcw
I have no experience but I've cannibalized/pieced together a vba Outlook macro that calls an outlook .oft template. The end result is that the user is prompted for entries like firstname, lastname, etc. which are added into the body of the email along with some static text. My end users are receiving an email from the scanner with a pdf attached. Rather than activating the macro (below) which creates a new email which they have to drag the pdf into, I would like them to be able to just run the macro directly on the email from the scanner so they don't have to bother finding the first email and dragging the pdf over to the new email.
How can I get this macro to forward an existing email rather than creating a new one?
Sub Statement_Email()
Dim myItem As Outlook.MailItem
Dim strRecipient As String
Dim strStatementMonth As String
Dim strThroughDate As String
Dim strHTML As String
Set myItem = Application.CreateItemFromTemplate("C:\Users\username\AppData\Roaming\Microsoft\Templates\Statement.oft")
strHTML = myItem.HTMLBody
strLastName = InputBox("Recipients Last Name?")
strFirstName = InputBox("Recipients First Name?")
strPrefix = InputBox("Recipients Prefix (ex. Mr., Ms., Dr.)?")
strMatterID = InputBox("Matter Number?")
strStatementMonth = InputBox("What is the statement date?")
strThroughDate = InputBox("Services rendered through what date?")
myItem.HTMLBody = Replace(myItem.HTMLBody, "%STATEMENTMONTH%", strStatementMonth)
myItem.HTMLBody = Replace(myItem.HTMLBody, "%THROUGHDATE%", strThroughDate)
myItem.HTMLBody = Replace(myItem.HTMLBody, "%RECIPIENT%", strRecipient)
myItem.HTMLBody = Replace(myItem.HTMLBody, "%PREFIX%", strPrefix)
myItem.HTMLBody = Replace(myItem.HTMLBody, "%LASTNAME%", strLastName)
myItem.Subject = Replace(myItem.Subject, "%LASTNAME%", strLastName)
myItem.Subject = Replace(myItem.Subject, "%FIRSTNAME%", strFirstName)
myItem.Subject = Replace(myItem.Subject, "%MATTERID%", strMatterID)
myItem.Display
This line: Set myItem = Application.CreateItemFromTemplate("C:\Users\username\AppData\Roaming\Microsoft\Templates\Statement.oft")
control what happens.
Assuming the message is selected, not open on screen, use
Dim oItem As Outlook.MailItem
Set oItem= Session.ActiveExplorer.Selection.Item(1)
set myitem = oitem.forward
dwebbcw
Thank you Diane.
I added those lines but am still having a problem. When the email with the attachment is highlighted in my inbox I click the quick launch icon to run the macro. I get an error that reads:
Run-time error '438': Object doesn't support this property or method.
Maybe I didn't add your lines correctly, this is what the entire macro looks like now:
Sub Forward_Statement2()
Set oItem = Session.ActiveExplorer.Selection.Item(1)
Set myItem = oItem.Forward
myItem.Display
Besides the typo in my last post (now fixed) - the top part of the macro is below. oItem is the original message, myitem is the forward.
Set oItem = Application.ActiveExplorer.Selection.Item(1)
strHTML = oItem.HTMLBody
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
Brostin Forward a mail to the address listed in the email text Outlook VBA and Custom Forms 1
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
D How to forward each email x minutes after it arrives in inbox and hasn't been moved or deleted? Using Outlook 1
W Macro to forward email Outlook VBA and Custom Forms 2
mikecox Forward email to another address; not with Rules Using Outlook 3
divan Macro to format email in a certain folder then forward to email address Using Outlook 3
R Auto-create receipt from email and forward to payer Using Outlook 3
C Unable to forward email with URL Using Outlook 2
M rule to change subject, pull email addresses from body, and forward with templ Using Outlook 14
A Outlook 2010 - Want to Have All Email Reply Forward as Rich Test Using Outlook 7
P email arrows - respond and forward Using Outlook 1
T Using A Rule To Forward An Email Containing Specific Word Using Outlook 5
D I would like to be able to Forward a Template to a specified email address on receiving an email in the Inbox. Using Outlook 1
L Automatically forward ALL outgoing/sent emails to another email adddress (not just for a specific distribution list) Using Outlook 2
T Exchange - forward email when user is not logged on Using Outlook 1
I Outlook 2007 Out of office Forward of email sent to a Distribution List member Using Outlook 1
O Can't send, reply, or forward email. Using Outlook 2
A Forward an entire email folder including the folder structure Using Outlook 2
P no text in forward email Using Outlook 2
A Outlook crashes and restart when I send, reply or forward an email Using Outlook 1
J Can not reply to or forward email from outlook but can send email started from new Using Outlook 1
O Email tool bar greyed out. Can't send or forward email. Using Outlook 1
R Exchange Powershell getting the forward email address for mailboxes Exchange Server Administration 2
A forward all email to another smtp server? Exchange Server Administration 5
B Outlook 2010 auto-forward deletes message text from forwarded email Using Outlook 7
L Forward Email and Insert Sender's Email address in body Outlook VBA and Custom Forms 3
M Forward email as insert from button Outlook VBA and Custom Forms 1
J Rule to Forward email but delay delivery 10 minutes Outlook VBA and Custom Forms 2
S forward email Outlook VBA and Custom Forms 1
C UDFs Reply vs Forward Outlook VBA and Custom Forms 2
C Don't forward duplicate Using Outlook 0
I change subject and forward without FW: Outlook VBA and Custom Forms 4
J Forward Action in Form Outlook VBA and Custom Forms 1
