Outlook gives warning using GO Contracts Sync Mod
Jack Poore
XP / Outlook 2003 /
I'm sure someone has to be familiar with GO Contacts Sync Mod. The program that can at least if not more, keep a live watch on your Google Contacts and live sync them to Outlook on your local drive. I keep getting this annoying alert, must be from Outlook, about a program wanting access to Outlook's contacts and one must reply okay. Is there some place in Outlook to turn this warning off? Of course I want to access the Contacts in Outlook, that's why I ran the program GO Contacts Sync Mod. I haven't been able to locate where in Outlook I can turn that warning off? Any assistance would be greatly appreciated. Jack ":-Dx
Jack Poore
No, I don't plan to upgrade. I just use this on some old XP's that will not die. I have a newer Win8.1 So I guess according to you post I just have to put up with it? I went to the link, briefly read there. Maybe it's saying there is a 3rd party program that might eliminate it? As far as anti-virus I use Windows Defender and I've not had a problem with being hacked in the 4 years I've used it exclusively. That or Windows Essentials. Thanks! jack ":-Dx
Yes, with Outlook 2003 you'll need to use a 3rd party program - either click yes to click the button, or either of the other two programs to bypass it.
J After Window update of 12/15/2010, outlook 2007 gives error (0x800CCC18) when accessing gmail using Using Outlook 6
C Upgrade to Outlook 2010 from 2003 Gives Thousands of Reminder Message Using Outlook 4
T Outlook 2010 gives an Outlook PST File Not Found error on Windows 7 32 bit. Using Outlook 1
H Office OUtlook 2007 gives error message that says to run scanpst.exe and this is not found on my com Using Outlook 3
J wireless always allows me to send/receive emails via outlook 2007. recent move to university gives me internet access but no emails can be sent or rec Using Outlook 1
P Outlook 2010 smtp.live.com gives error that server does not support encryption. Using Outlook 2
M outlook client gives security alert after setting up EX2010 owa on server Exchange Server Administration 7
D Outlook 2010 Outlook in Windows 10 keeps asking for user name and password repeatedly Using Outlook 14
J How do I disable advertising in Outlook 2019? Using Outlook 10
B Outlook Calendar not coming down from cloud Using Outlook 2
J Are the underlined letters in Outlook Reminders window supposed to work? Using Outlook 0
M Office 2016 Outlook is forgetting passwords Using Outlook 15
Wayne Outlook locks up when opening "Manage Rules & Alerts" Using Outlook 3
G Personal Settings within Outlook Using Outlook 2
V Outlook Forms: Formatting a Label with 2 different styles Outlook VBA and Custom Forms 1
M Outlook 2016 Outlook randomly unhides from taskbar Using Outlook 12
D Sending email from Office 365 alias in Outlook Using Outlook 3
B Spam folder not showing in Outlook Using Outlook 5
ThinkToday Calculate reply time of outlook mail Using Outlook 1
M Microsoft 365 Outlook keeps requesting password on Local Account Using Outlook 1
