Parts of Outlook UI transparent
Vincenzo
When my friend starts Outlook 2013 on her Win 8 computer, some parts of the interface are transparent - you can see the Desktop that is behind Outlook. The parts that are transparent are the area above the Preview Pane, and the area below the Preview Pane (the People Pane).
You can see the Desktop icons behind Outlook, but clicking on them has no effect.
If you minimize Outlook and then maximize it, the problem usually goes away for a while.
Any ideas about this?
Vincenzo
Thanks for the suggestion.
I've just tried that and the issue remains. Thanks for pointing me in the direction to look. Do have any thoughts on where to take my search? Windows says I have the latest driver.
M font format discrepancies with Quick Parts Using Outlook 1
C Quick Parts signatures suddenly require more letters Using Outlook 2
B Push Quick Parts to All Users Using Outlook 1
D Quick Parts - font changes Using Outlook 6
D Quick Parts - font changes Using Outlook 0
S Inserting Dates With Quick Parts (or Macros) Using Outlook 4
S Quick Parts - Changing Display and Order Using Outlook 0
O Outlook 365 - Gmail and Outlook: how to force Outlook to start up in Gmail? Using Outlook 2
