Help with macro to answer and delete calendar requests?
EdNerd
Outlook 2007
I copied the following code from http://www.slipstick.com/outlook/calendar/autoaccept-a-meeting-request-using-rules/ to accept calendar requests. It works, except for three questions.
Sub AutoAcceptMeetings(oRequest As MeetingItem)
If oRequest.MessageClass <> "IPM.Schedule.Meeting.Request" Then
Dim oAppt As AppointmentItem
Set oAppt = oRequest.GetAssociatedAppointment(True)
Dim oResponse
Set oResponse = oAppt.Respond(olMeetingAccepted, True)
oResponse.Display
oResponse.UnRead = False
oResponse.Delete
Questions:
(1) I get a pop-up prompt every time "The sender will not be sent a response. Is this okay?" Of course it is - that's why I'm doing this by code. :8>) Is there any way to not see this pop-up?
(2) The .Unread is NOT marking the item as Read, at least as it's displayed in my Inbox. Do I have the wrong property?
(3) .Delete is not deleting the item from my Inbox. Is there a different way to do this?
Ed
EdNerd
Outlook 2007
1. to save with no response sent use oResponse.Close (olSave).
Okay - I commented out .Display and inserted .Close -- thank you!!
2. oResponse is what you send back, oRequest is the message in your inbox.
3. Same for .delete.
D'oh!! Of course! :8>\
Thanks for the boost.
Ed
EdNerd
Outlook 2007
Okay -- we just got "upgraded" to Office 2013. (The jury is still out on the "up" part!!)
My macro creates a response and deletes the request.
But the response gets saved as a draft and is not added to the calendar.
Does this need to be adjusted for OL13?
Dim oResponse
oRequest.UnRead = False
oRequest.Delete
EdNerd
Outlook 2007
I adjusted the macro. It saves to the calendar. But it also saves a draft.
Can I avoid creating the Draft? Or do I have to intercept and delete it?
Here's the part that's doing the work:
  Dim oResponse 'As MeetingItem
  oRequest.Delete
try oldiscard instead of olsave.
(I think cached mode is the cause - it syncs before all of the changes and gets confused.)
A newb outlook macro help Outlook VBA and Custom Forms 1
A Help creating macro for conditional formatting settings Using Outlook 8
S Help macro Outlook VBA and Custom Forms 1
C Help with a Macro to move emails to a different PST data file Using Outlook 4
F Help with Outlook 2007 Macro Please! Using Outlook 4
S Outlook macro help Using Outlook 10
P Please Help me Create a Macro ! Using Outlook 2
D Help with simple macro - looping though all emails in my inbox Using Outlook 3
S Macro help Using Outlook 4
S Outlook 2003: Help with setting up a macro to reply to selected emails Using Outlook 2
M Help - VB Macro no longer work Outlook VBA and Custom Forms 5
S MAcro - Need help in getting the recipients in to filed / cc field toput in an array Outlook VBA and Custom Forms 4
L Help for writing an Outlook 2007 macro Outlook VBA and Custom Forms 7
V Outlook macro help please Outlook VBA and Custom Forms 23
B HELP! Using Outlook 4
M Winmail. dat - HELP Using Outlook 2
Diane Poremsky Help! My Contacts are being updated! New Slipstick.com Articles 0
B VBA Help Email that will save as draft and send as attachment Outlook VBA and Custom Forms 3
J Can Anyone Help?? Outlook VBA and Custom Forms 1
