Button in body of email to approve/reject with original text
Erin
I'm looking for a slight variation of what is already posted, if you can lead me in the right direction or to the solution, I would appreciate it.
I would like to create a button in the body of the email template that would allow users to approve a scenario with comments or reject a scenario with comments AS WELL AS include the original text of the email.
I am not satisfied with the voting buttons. This will only go to 1 (2 people max) I'm worried if the original sent mail accidentally gets deleted, my approvals/rejections will be deleted as I will be using this template in a shared mailbox.
Any suggestions on how I can acheive this without using voting buttons? It's important that I receive something confirming the words APPROVE/REJECT for audit purposes so cannot rely on a simple email response.
Forum Admin
The problem with including buttons in the body is that Outlook doesn't support active content in Email... you'd need to use a custom form and a control button - but that only works well if the form is published to an Exchange organizational forms library. If you just need a message that says 'approved' or 'rejected', you could use a mailto link - using the relevant information (Subject: "Rejected: Thing that was rejected") to create the link would require scripting. (Mailto links can include subject and body text.)
J "Contact" button in Journal entry Using Outlook 1
N Which Button Was Clicked on the Ribbonbar Menu Outlook VBA and Custom Forms 2
E Can't accept or decline task (no button appears) Using Outlook 2
witzker Outlook 2010 Insert Date & Time at the button of an OL contactform in red Using Outlook 2
J Command Button to stamp a date and time in a textbox in Outlook 2016 Outlook VBA and Custom Forms 3
A ScanPST finding errors but no Repair button Using Outlook 2
N Creating a button or link to a form in the Organizational Forms Library Outlook VBA and Custom Forms 3
D Command Button code will not execute. Any suggestions Please. Outlook VBA and Custom Forms 2
S Reminder Dialog Open Button Using Outlook 2
Wayne Dardis Calling Ribbon Button in Outlook 2016 Outlook VBA and Custom Forms 6
E Button to change subject Outlook VBA and Custom Forms 1
S Shortcut/button to a Calendar Group Using Outlook 0
I Creating meeting invite with disabled tentative button Outlook VBA and Custom Forms 5
Diane Poremsky Contacts are missing when you click the To button Using Outlook 0
T Unable to 'Upload a file' using popup 'Browse' button Using Outlook 0
makinmyway ScanPST.exe Missing Repair Button Using Outlook 15
K Remove Manage APPS button for users Exchange Server Administration 1
J Send and Receive Button - only check default account? Using Outlook 1
A custom send button Outlook VBA and Custom Forms 3
P Possibility to create a calendar button "remaining week"??? Using Outlook 3
H Preventing the Send button from being clicked on an Outlook Form Outlook VBA and Custom Forms 1
S Create a custom "Send" Button Outlook VBA and Custom Forms 3
makinmyway Can I add a Map It Button to Custom Contact Form? How? Outlook VBA and Custom Forms 6
R How can I retain embedded object with voting button reply? Using Outlook 5
G Moving "Delete" button on Outlook for Mac Using Outlook 1
K OL2010 Button to Insert First Name Outlook VBA and Custom Forms 6
K OL2010 Button to Insert First Name Using Outlook 1
R Outlook 2013 People Pane - Where is the "Add" button for social networks? Using Outlook 4
C Button to Forward and Move Using Outlook 4
A delete button on message list disappeared Using Outlook 19
