Using Outlook 2007 with Comcast (.pst inbox issue)
terrwise
Outlook 2007
Just changed to Comcast for internet and email. We have been using Outlook 2007 with prior email account using the folders (i.e. Inbox, Deleted Items, Sent, etc) in Outlook>Personal Folders. Followed the steps provided by Comcast to set up Comcast account in Outlook. Have no problem sending from Outlook but no emails were coming into Outlook>Personal Folder>Inbox. Determined that a new folder on same level as Outlook Personal Folder was created named for Comcast Email. Within that Folder are "New" Inbox and Junk E-mail folders. All the incoming mail from Comcast is going to a "New" Inbox under a Comcast Email Folder. And when we delete an email in "New Inbox" it just sits there with a line thru it - doesn't move to Deleted Items under Outlook>Personal Folders. Is there any way to Comcast emails to go into the "Old" Inbox under Personal Folders (which is showing as the default file in Tools>Account Settings>Data Files)?
The new account is an imap account - it has it's own data file as you have discovered. IMAP is mail only, so you need the old pst for calendar and contacts. When you delete mail in IMAP, it's marked for deletion. You can set outlook to purge the deleted items when you change folders or hide the items marked for deletion. Purge options are on the Edit > Purge menu in Outlook 2007.
If you want Comcast mail in the old folders, you need to delete the imap account from outlook and add it back as pop3. The advantage of imap is that it leaves mail on the server so it syncs well with multiple computers and smartphones or tablets.
R Using Internet Calendar in Outlook 2007 within Citrix Using Outlook 1
S Can't send messages using Outlook 2007 from a business email Using Outlook 3
K Outlook 2007 using in office and at home Using Outlook 1
D folders are missing using imap outlook 2007 Using Outlook 1
F Using Outlook 2007 as an IMAP Mail Station Without Saving Data Locally Using Outlook 2
M Scared to lose data using iCloud with Outlook 2007 Using Outlook 2
M Syncing using iCloud mangled my Outlook 2007 file Using Outlook 2
M Unable to send email to gmail - using Outlook 2007 Using Outlook 3
L How can I delete stationery from Actions, New Mail Message Using in outlook 2007? Using Outlook 6
D using outlook 2007 categories through gmail Outlook VBA and Custom Forms 2
S Sending Email from Access 2007 through Outlook 2007 using template Outlook VBA and Custom Forms 13
C Not able to send emails with Outlook 2007 using Vista BCM (Business Contact Manager) 1
S Outlook 2007 error message using the TASK feature Using Outlook 6
J Outlook 2007 using custom form created for Outlook 2003 Outlook VBA and Custom Forms 2
S save attachment using outlook 2007 Outlook VBA and Custom Forms 1
M Using Outlook with Yahoo email Using Outlook 6
D send email from Excel using outlook template Outlook VBA and Custom Forms 3
R Using Multiple Accounts in Outlook Using Outlook 3
Diane Poremsky Using Outlook Links Using Outlook 0
Diane Poremsky Using Arrays in Outlook macros Using Outlook 0
Diane Poremsky Using the Outlook Calendar Template Using Outlook 0
N Going Forward: Using Outlook 2016 for RSS Feeds Using Outlook 2
Diane Poremsky Using Scanpst in Outlook Click to Run Using Outlook 0
Diane Poremsky Using Outlook's New Contact Cards Using Outlook 0
