Hae Rules NOT perform automatically?
GigaFluxx
Hi everyone,
I'm fairly basic when it comes to using Outlook as I normally stuck to web based clients and minimal organization. Then I got my new desk job and well, now it's a matter of learning a ton of new info.
Anyway, I have a lot of sub folders (in an archive) for which to organize my e-mails and at first I created a bunch of rules that would place them in the correct folders for me. What I found though is as new e-mail came in, they would automatically be sorted into those folders making it difficult to keep up with new unread messages, and so I just had to delete all the rules.
Now what I would like is to make rules that follow the same instructions but ONLY when I manually run the rules. That way new e-mails will filter into my inbox and once I'm up to date, I just run the rules and they get sorted. Is this possible?
Forum Admin
If you don't add a check in the box next to rule name the Rules Wizard, they will only run manually... or let them run as mail arrives and use the Unread Search folder to read new mail.
Wayne Outlook locks up when opening "Manage Rules & Alerts" Using Outlook 7
B Setting rules Using Outlook 1
A rules not working Using Outlook 2
M Rules and autoreply Using Outlook 1
O How to recover rules after switch from POP3 to IMAP Using Outlook 2
N Copies of emails from rules have wrong from: account Using Outlook 0
L Office 365 cloud based rules Using Outlook 1
CWM030 Rules disappearing in OL 2016? ( Yes, I searched before posting) Using Outlook 7
R When rules lose track of "specified folder" Using Outlook 6
I Outlook 2013 Rules - (client only) Using Outlook.com accounts in Outlook 1
A rules (flags) not working Using Outlook 7
K Lost Rules. Assistant accesses my mailbox. Disappeared Using Outlook 0
R When rules are working but invisible and unmanageable Using Outlook 2
P Transport Agent or Rules/Connectors Exchange Server Administration 1
O Rules and Alerts for New Messages BEFORE sending Using Outlook 2
D Outlook Rules Using Outlook 1
Diane Poremsky Autoaccept a Meeting Request using Rules New Slipstick.com Articles 2
Gunny NFOhiway Outlook PST file and Rules Using Outlook 1
M Outlook 2016 Rules Not Working Automatically Using Outlook 5
Diane Poremsky Rules & Alerts Dialog Won't Open New Slipstick.com Articles 1
P Log of Rules that ran Outlook VBA and Custom Forms 3
P Recover / Extract Rules from standalone PST file creating RWZ file Using Outlook 2
T Client-side rules not working, but no error Using Outlook 1
R Missing Quick Steps and Rules Using Outlook 0
Diane Poremsky Delegates, Meeting Requests, and Rules New Slipstick.com Articles 0
A outlook 2007 how to chcek all rules ? Outlook VBA and Custom Forms 2
J Outlook Rules not show Master Category List Using Outlook.com accounts in Outlook 4
mikecox Forward email to another address; not with Rules Using Outlook 3
