Outlook won't open. PST file busy.
JRubin
Outlook 2013 64 bit
Hello - I'm stuck.
User sees intermittent (but all to often) error stating Outlook 2013 unable to open. PST file is in use. User can restart the laptop numerous times without this problem stopping. I've run scanpst upon ocassion, without success. Just read that Diane suggests running it three times, which I'll do. Any other suggestions?
OS: Windows 8.1
Sync: Android Sync
A/V: Bitdefender 2015 Total Security
Inbound: IMAP
Did you try a new profile? I had a client this morning that kept getting errors about the pst file in use and it went away when we made a new profile. She only had 1 email account (gmail imap) in her profile, so it wasn't painful to recreate.
JRubin
Outlook 2013 64 bit
Hi Diane, thank you for replying. I have in the past, but the problem returns. What I didn't know is that I had to run SCANPST multiple times before a PST file might be repaired. I had to run it 6 times before it came back and reported things were ok. No complaints today, so we'll see. I did learn today that sometimes the client forces a shutdown because no program is displayed as being open. I explained to him that just because he doesn't see the program open, doesn't mean the file has been closed. I pointed out that being we're typically talking only @15 seconds, it would be wiser to just let the computer shut down on its own. So, perhaps that was the issue.
Well, that will cause corruption. There should be a gray outlook icon in the tray when it's still shutting down.
M outlook won't open! Using Outlook 1
Diane Poremsky Outlook 2013: Control Panel Mail Won't Open New Slipstick.com Articles 0
Diane Poremsky Outlook Links Won't Open In Windows 10 New Slipstick.com Articles 1
L Outlook 2013 won't open MS Office attachments Using Outlook 1
B Add-in "always enabled" but Outlook 13 won't open Using Outlook 7
J links won't open from Outlook Using Outlook 1
M Outlook Express won't open Using Outlook 1
D outlook won't open attachments Using Outlook 1
S Outlook 2010 won't open in Regular mode, Only Safe Mode, I've disabled all plugins... Using Outlook 1
R Microsoft Outlook won't open Using Outlook 3
M Outlook 2007 - Contact detail won't open Using Outlook 2
A Outlook 2010 won't open, seeking MS Exchange. Using Outlook 2
G Outlook 2010 won't re-open (or rather, never really closes) in Windows 7 Using Outlook 1
G Outlook won't open and received the scanpst.exe error. Using Outlook 2
D outlook won't open website links of php files. Using Outlook 2
G outlook 2010 won't open in windows 7 Using Outlook 6
J Outlook won't open after installing Office 2010 Using Outlook 1
M Outlook 2010 won't open in standard mode Using Outlook 4
K Outlook 2007 When I attempt to open a new email, it won't open and says 'not responding' Using Outlook 5
S Detail view of individual contact in outlook won't open Using Outlook 1
B Outlook 2003 won't open using VPN from home Using Outlook 1
C Outlook 2003 won't open Using Outlook 2
L Outlook 2007 won't open unless i restart my computer. Using Outlook 1
D Outlook 2010 won't open attachments on Windows 7 machines Using Outlook 2
H Outlook 2007 was working fine and now won't open. Using Outlook 2
E Microsoft Outlook won't open Using Outlook 3
S Re: Outlook 2007 won't re-open once closed Using Outlook 1
A Outlook 2003 won't open Using Outlook 2
B Microsoft Outlook won't open Using Outlook 1
D Outlook 2007 won't open without granting access to the program. Using Outlook 5
V Scanpst reports no errors in PST file, but Outlook 2007 won't open, reports errors. Using Outlook 2
K word 2007 attachment won't open on windows 7 machine using Outlook Web Access v2003 Using Outlook 1
W Outlook '03 - Won't open path not longer applies Using Outlook 1
K Outlook won't stay open Using Outlook 12
R OUTLOOK 2000 WON'T OPEN Using Outlook 3
A Outlook 2010 won't open when opening a .ics file Using Outlook 1
K Outlook 2007 Won't Open in Normal or Safe Mode Using Outlook 2
R Outlook won't open Links in mail messages Using Outlook 2
P Outlook won't open links in received e-mail messages: "Windows can't open this file:" Using Outlook 2
A MS Outlook won't load... Error message>>> "Cannot open your default e-mail folder:" Using Outlook 4
V Outlook Calendar Won't open! Using Outlook 6
S Outlook Won't Open in Windows 7 64 bit__Please, Urgent, my life and small business is in Outlook Using Outlook 11
I Windows outlook won't open Using Outlook 3
E Outlook 2007 won't open after Windows 7 updates installed. Using Outlook 17
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
soadfan Outlook won't send e-mail when offline Outlook VBA and Custom Forms 19
P Outlook 2016 won't Start Using Outlook 3
Phil52 Outlook won't work Using Outlook 1
T Outlook 2010 calendar won't sync with Android phone Using Outlook 3
