Adding contacts on Android phone and then syncing them to Outlook
Ascar_CT
Hello everyone,
I have noticed a strange thing which gets in the way of adding contacts to my address book.
When I add a contact on Android phone I enter the email address in the email address field and choose that this is a “work” email address.
Android phone syncs contacts to my outlook.com address book. In a few minutes I see the new contact in both Outlook.com and in MS Outlook 2010 address book. However what I see in both Outlooks is quite different from what I entered on the phone. In MS Outlook Contacts I see that the field which has to hold the email address also has the name of the contact in double quotes and the email address has the <> symbols prepended and appended. I did not enter any of these symbols. Outlook.com also shows this email address as “Personal” despite I set it as “Work”.
Now, if I need to send an email to this contact from Outlook and I pick up the email address details from the address book the message does not send and gets stuck in the Outbox because the mail server does not understand "Bill Clinton" <bill.clinton@xyz.com> because it should be just the email address without any additional characters. So, for me to make this record in the address book work I have to edit it manually.
Do you know of any fix or workaround for this problem?
The brackets shouldn't affect the address - the name <address> format should be understood by all mail servers. Outlook desktop doesn't understand home and work addresses - its just an address. However, there is a problem based on the display name field - only the address should be inside the () and there should only be () or <>, not both.
You are using the default android contact app? I'll repro it and report it.
Ascar_CT
Yes, if I had just brackets, it would have worked because mail server is supposed to ignore these characters. But I get Name + Last Name + some spaces in the email address field.
I use stock Android contact manager, however since my phone is Samsung Note 3 I am not sure how much "stock" it is in view of Samsung's notorious penchant to modify the standard Android stuff.
Shaun_G
Outlook.com (as MS Exchange)
Has a resolution been found for this issue?
I have also found that the problem exists with email address formats in Outlook.com when saved from stock Android (Kit Kat 4.4) contact manager.
When in the People section of Outlook.com and with a specific contact selected, there are no issues sending an email by clicking on the persons email address. (See the following screenshot.)
However, when in Compose mode in Outlook.com, there is an error after entering the recipient and trying to send the email. (See the following screenshots. Note: these are not issues when sending an email from with the People section.)
(Screenshot after manually entering the persons name from list of recipients in Outlook.com.)
(Screenshot after clicking send button.)
The only work around is manual removal of the contact name and greater than and less than marks from either side of the email address in the email field, as seen in the following screenshot.
Thanks for any assistance on this issue.
Ascar_CT
No, I gave up on this. Even if I add a new contact on the phone this would be just for the phone number. I add email addresses from inside MS Outlook. I very rarely use Outlook.com webmail. Let's see if this problem clears after we all transition to Exchange server on the back-end.
Commodore Editing contacts and adding photos Using Outlook 4
B Automatically adding contacts to address book Using Outlook 2
R adding field from Contacts Using Outlook 0
L Adding custom labels in Contacts BCM (Business Contact Manager) 1
K Adding Customer ID automatically to contacts BCM (Business Contact Manager) 1
N Adding 'Add To Business Contacts' when right-clicking an email add BCM (Business Contact Manager) 2
R Adding contacts to Outlook from Access DB Outlook VBA and Custom Forms 1
G Removing old emails when adding accounts Using Outlook 3
D Contact Group - Adding Bulk Addresses Using Outlook 2
E Project Management - Adding Folders for Different Folder Types Using Outlook.com accounts in Outlook 0
O Adding a new account - "CompanyL (none)" line is added Using Outlook 5
W Adding A Macro To Message Ribbon Outlook VBA and Custom Forms 2
I Collecting mail address from GAB and adding to Outlook Task Using Outlook 2
A Outlook 2016 - adding outlook.com account creates a new/strange address Using Outlook.com accounts in Outlook 18
F Adding textbox filter to listbox? Outlook VBA and Custom Forms 2
J Adding Reply & Delete to main toolbar? Using Outlook 0
T Outlook 2007 adding categories Using Outlook 15
Diane Poremsky Adding Emojis to Outlook's AutoCorrect Using Outlook 0
T Adding "Mark As Complete" btton to Task Remindet Pop-Up Using Outlook 3
A Adding a 2010 sharepoint contact list to outlook 2010 address book Using Outlook 1
M Adding fields to Task in Outlook Home and Business 2010 Outlook VBA and Custom Forms 7
S Using Send on Behalf is adding extra data in from line Using Outlook 1
Lucylou Outlook 2013 Adding Outlook.com breaks profile, "Outlook not working" messag Using Outlook.com accounts in Outlook 1
C Adding Categories when Composing Email Using Outlook 1
stephenjones Adding a business account to Outlook Using Outlook 1
Chris Grew Adding 2nd Email Address BCM (Business Contact Manager) 3
