Editing an email with notes and saving it for record using Macro
Shreekant
Is there a was to Edit an Email with notes and saving it.
The action would be similar to opening an email, and under Actions, choosing EDIT,
Enter " Action completed by " the editor of the email, on mm/dd/yyyy at hh/mm.
Any help would be greatly appriciated.
Michael Bauer
This writes something at the beginning of the email:
dim Mail as outlook.mailitem
set mail=application.activeexplorer.selection(1)
mail.body="your note" & vbcrlf & mail.body
mail.save
Shreekant
mail.save
Thanks....Almost there, I also need to capture the userid oremail of the person eding the email.
so if i am editing the email out of my account, my name will be there and so forth.
L Editing auto reply email from a shared mailbox? Exchange Server Administration 7
F add new panel to email editing window Outlook VBA and Custom Forms 2
S Editing Tasks in Outlook 2016 Using Outlook 6
N editing drafts - won't let me save Using Outlook 12
evdbogaard How to dock the Styles Task Pane in the e-mail editing window? Outlook VBA and Custom Forms 1
J Forward Message after editing attachments and include edited attachments Using Outlook 5
Diane Poremsky Editing the Subject Line in Outlook New Slipstick.com Articles 0
Q Editing an outlook. Template file (Otk) Using Outlook 1
mrje1 Note Field (Any way to do incell editing) Using Outlook 7
D Conflict warning while editing Exchange Server Administration 0
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
Brendan.Z Outlook 2013 signature editing issue Using Outlook 3
Commodore Editing contacts and adding photos Using Outlook 4
Diane Poremsky Pasting VBA code (and other editing) Outlook VBA and Custom Forms 4
M Editing tasks: highlight & copy/cut NOT working in Calendar entries Using Outlook 4
K Editing a .PRF file for new users after deploying Outlook 2010 with MSP Using Outlook 5
A outlook printing assistant Help editing template Calendar Printing Assistant 3
K Outlook 2013 - Inline Editing of Contacts Using Outlook 4
B Editing Calendar Categories Using Outlook 3
C Outlook editing won't select just one word Using Outlook 1
G Editing the Read Receipt Using Outlook 1
J Outlook 2010 Editing Forms Using Outlook 3
J Joint Calendar Sharing - Editing Using Outlook 1
T Editing Mailing List BCM (Business Contact Manager) 1
W Reply to email Using Outlook 4
B disappearing original when attach to email Using Outlook 1
