Message template / custom forms and VBA Help needed - inserting info into table
GingaDave
Outlook 2013 64 bit
Exchange Server 2010
Hi, I'm stuck and i am needing help.
i have created a message template to be used for admin, but they want their lives made easier. Now the boss has asked me to sort it out.
Basically, the issue is this. Below is an image of the template. It was created in a table. at the moment the admin are filling in all fields themselves. Now they want some fields filled in automatically. The fields they want auto-filled are :
Date created: - Populates the date that the message was created.
ATTACHED FOR REFERENCE - This is a list of all of the attachments that have been attached to the email.
FILE PATH STRUCTURE ON SERVER - This is a list of the location where the attachments were inserted from. ( eg c:/jobs/5467/pdfs/drawing0042.pdf )
I have found some code from other places that help me to some point with the 1st field and 2nd field but not the 3rd field.
1st field - the code works (from Diana - thanks) but i need it to be in the correct cell.
Sub StampDate()
   Item.DTS1 = Now()
Sub InsertDate_Click()
  Call StampDate()
2nd field - this also needs to be in the correct cell, and also i cant seam to create a custom form button to run this script (would be nice if it was one button for all )
Sub Names()
Dim Atmt As Attachment
Dim Mensaje As Outlook.MailItem
Dim Adjuntos As String
Dim Body As String
Dim i As Integer
Set Mensaje = Application.ActiveInspector.CurrentItem
Mensaje.BodyFormat = olFormatHTML
Body = Mensaje.HTMLBody
i = 0
Adjuntos = ""
For Each Atmt In Mensaje.Attachments
    'If Atmt.Size > 5 Then
    Adjuntos = Adjuntos & "** Attached file: <u> " & Atmt.FileName & " </u> <br>"
    i = i + 1
    'End If
Next Atmt
Adjuntos = "<u> <b> Total number of attached files: " & i & "</u></b> <br>" & Adjuntos
Mensaje.HTMLBody = Left(Body, InStr(Body, "</body>") - 1) & Adjuntos & Right(Body, Len(Body) - InStr(Body, "</body>") + 4) & Format(Now)
Set Mensaje = Nothing
3rd field - Total loss - i need the code and button (again if was same button would be fab)
Cheers
GingaDave
GingaDave
Outlook 2013 64 bit
sorry - mistype in stampdate code - should read
Sub StampDate()
   Item.body = Now()
  Call StampDate()
Michael Bauer
Access user properties this way
item.userproperties("name").value = "abc"
As to the third issue, I don't know a way to get that info from Outlook. I think you'd need to write the part to add the attachment to the email yourself. If you drag an item to the email, the file path is available in the clip board.
The date stamp code is vbscript and added to the form. To the best of my knowledge, you can't work with cells using vbscript. You can do it in word using VBA - so as long as you are using VBA and not a script in the custom form, you might be able to get it into the cell. (Command buttons on forms use VBscript... )
This is the code i use in Word to read the cell in the first row, 3rd column in the first table. In a quickie test the other day, I tried converting it to Outlook but didn't get the tables referenced right.
Dim myTable As Word.Table
Set myTable = ActiveDocument.Tables(1)
txtNotes = myTable.Cell(1, 3)
Making your other macro work with a command button starts with changing the name to match the button name - like the Sub InsertDate_Click() is named. I believe this only works with vbscript (Michael will correct me, if I'm wrong). If so, you would need to convert the macro to script - there are subtle differences between vbscript and VBA and not everything is supported. I haven't looked closely at your code to know if it will work in vbscript. It is possible to call vba from a script, but it's not something microsoft recommends (plus the form is no longer self-contained and not as easily shared).
R How to design custom template under message/mail form ! Using Outlook 0
L reply to message using a custom template Using Outlook 1
J Adding original email text to outlook message template Outlook VBA and Custom Forms 2
J New e-mail message template Using Outlook 1
N How to automatically update all fields in an Outlook message template (OFT)? Using Outlook 9
L Using a template for new email message, changes are not saved unless I send the message...using Wind Using Outlook 3
P Cannot save new Outlook 2007 message as a Word template to share Building Blocks/Quick Parts Using Outlook 2
C Why won't Title display in message list? Using Outlook 1
icacream content in this message could not be downloaded.... Using Outlook 2
R Warn before sending message Outlook VBA and Custom Forms 4
M Message list font changed after update Using Outlook 2
T Change the selected Message in the Outlook window Outlook VBA and Custom Forms 2
evdbogaard Reply with only last message cited Using Outlook 1
T O365 and Office Message Encryption Exchange Server Administration 2
D Outlook Message Window Changes Size and Position Using Outlook 1
P Message List Font Changed Using Outlook 6
B Search: Cannot find which Folder Contains a Message Using Outlook 3
E Search for folder by key in subject then move new message to related folder Outlook VBA and Custom Forms 1
D Paste Excel table into Outlook message Outlook VBA and Custom Forms 6
W Message Text Using Outlook 1
J Searching message folder in Outlook 2016 Using Outlook 5
GregS Very Confusing PST/OST message Using Outlook 2
