bcm 2010 download does not recognize outlook
Carmen
Just got a new pc. Having the same problem as below. I have downloaded the 368 mb file. My computer is up to date. Any suggestions?
Got a brand new PC, and as I trying to install BCM, I keep on receiving this error ”business contact manager requires that outlook is installed on the computer". Any insights?
I'm using the 32 bit BCM on a 32 bit Office. If I run the installer when outlook is running, I get the msg that office needs to be closed.
Dec 7, 2014 Flag Post
#1 Share
Which BCM are you installing? Are all updates for Office installed?
You need the 368mb file. I'd use the new update (released Nov 2014) but it might do a version check - so make sure all updates are installed.
Carmen
No other office suites installed. Yes, Send by email command works in other applications. Funny, I had not replied to your response because I finally got it working back in Feb. I had to uninstall due to a corrupt file, and now am back at square one again. Unfortunately, I did not write down what worked the last time! Any other suggestions? Thank you.
Carmen
Sorry, I missed some of your questions above. I have Office H&B 2010 disk. I made sure all my updates are current. Downloaded the BCM 2010 file from the link you gave above (release date Nov 2014).
Forum Admin Download BCM 2010 BCM (Business Contact Manager) 0
Forum Admin BCM Update for Outlook 2010/2013 - Nov 2014 BCM (Business Contact Manager) 14
JimR BCM 2010 or 2013 BCM (Business Contact Manager) 6
J Migration from BCM 2010 to 2013 is messing up the label fields BCM (Business Contact Manager) 4
T BCM 2010 Archiving Communication History BCM (Business Contact Manager) 2
R BCM 2010 Problem with remote office (VPN) users cannot connect BCM (Business Contact Manager) 12
C Trying to move my Business Contact Manager ver. 2003 to BCM ver. 2010 Using Outlook 3
R BCM is almost at capacity Outlook 2010 BCM (Business Contact Manager) 2
O Is it possible to go from BCM Office 13 back to BCM Office 2010? BCM (Business Contact Manager) 1
V Permissions in BCM 2010 BCM (Business Contact Manager) 3
M Is there a list of FieldNames that BCM 2010 uses? BCM (Business Contact Manager) 0
A BCM 2010 converts html e-mails to plain text BCM (Business Contact Manager) 1
A BCM 2010 account names import in reverse order BCM (Business Contact Manager) 4
B BCM 2010: Exporting Notes to .CSV with Business Contacts? BCM (Business Contact Manager) 3
J BCM 2010 - New user cannot connect to remote DB BCM (Business Contact Manager) 5
E Can we make custom form as default form in BCM 2010? BCM (Business Contact Manager) 5
N BCM 2010 for CRM tool? BCM (Business Contact Manager) 3
S BCM 2007 to 2010 migration failure issue BCM (Business Contact Manager) 1
R Sorting and crossing over project tasks in project window (BCM 2010) BCM (Business Contact Manager) 1
M BCM 2010 Cannot Connect to Remote Database BCM (Business Contact Manager) 1
M BCM 2010 Link to Record (very) slow BCM (Business Contact Manager) 2
D [SOLVED] Optimizing Outlook 2010 BCM BCM (Business Contact Manager) 2
C Outlook 2010 with BCM - Database Connection problems using Windows 7 Clients Using Outlook 1
T Custom forms BCM 2010; use of form controls Using Outlook 1
S Recovering .sbb file that should be a .bcm file for Business Contact Manager 2010 Using Outlook 3
N Receive "Requested Operation Failed" Dialog when trying to add BCM Database in Outlook 2010 Using Outlook 2
P Communication History disappeared in BCM 2010 Using Outlook 22
C BCM 2007 to 2010 Migration BCM (Business Contact Manager) 1
R Missing contacts and Opportunities in BCM 2010 Shared database BCM (Business Contact Manager) 1
M BCM for Outlook 2010 now on Technet BCM (Business Contact Manager) 2
J BCM 2010 BCM (Business Contact Manager) 1
G Small Businesses Owners being priced out of BCM 2010 BCM (Business Contact Manager) 2
J Where is Final Release BCM 2010, Microsoft? Why is Dev Team silent BCM (Business Contact Manager) 2
L Cannot install BCM 2010-"Outlook 2010 Not Installed" but it is! BCM (Business Contact Manager) 1
B Where is RTM version of BCM 2010? BCM (Business Contact Manager) 2
R BCM 2010 error creating offline copy of shared database BCM (Business Contact Manager) 1
T BCM Install fails Both w Off. Pro 2010 Beta & on reinstall Off.Pro BCM (Business Contact Manager) 5
C BCM for RTM Release of Outlook 2010 BCM (Business Contact Manager) 3
S RE: BCM won't open after installing Office 2010 Beta BCM (Business Contact Manager) 2
K BCM 2010 report error BCM (Business Contact Manager) 6
B Multiple businesses in BCM 2010 BCM (Business Contact Manager) 9
