BCM suddenly crashed and not able to view specific business contact.
nisha
When I try to open BCM I get the following error message "Business Contact Manager for Outlook could not complete your last action or actions. Please try again." When I click on the OK button the error message disappears.when click form layout, that time also "Business Contact Manager for Outlook could not complete your last action or actions. Please try again." message is displaying and not able to customize business contact form. This problem started recently suddenly.I am using shared database for BCM
Does it only happen when you try to customize the form or does it happen all the time? I've had similar errors and fixed it only after reformatting. Do you have the newest BCM installed? (Released in Nov 2014.) If not and you decide to update, everyone using the database needs to update.
Diane Poremsky Restoring BCM Database After Upgrading Windows New Slipstick.com Articles 0
Diane Poremsky Outlook 2016: No BCM New Slipstick.com Articles 0
Diane Poremsky BCM Errors after Upgrading to Windows 10 New Slipstick.com Articles 1
R Installing BCM BCM (Business Contact Manager) 0
G Future development of BCM BCM (Business Contact Manager) 5
A Send email from BCM BCM (Business Contact Manager) 5
