Auto scan/send
Bryan
Outlook 2013 32 bit
Exchange Server 2013
I am still new to the coding world and I could use some help. We are trying to set up outlook to automaticly scan the inbox for a specific subject line in an email. Once that has happend we need outlook to send an email stating that the email in question has been recieved or has not been recieved. This will be used to verify that emails dealing with reports have been sent out, now I have been able to set up outlook to send an auto email when it recieves the report email by using the rules in outlook. The problem I am having is setting outlook up to scan the inbox at a specific time and then send out a "Did not recieve" email if the report email does not come in. One of my co-workers sugested that I use this code and try to modify it to suite our needs, and this code works fine but it has to be run manualy and to only gives a pop up box. Any ideas? I am greatful for any help I can get.
If Item.Class = olTask Then
If InStr(Item.Subject, "subject") > 0 Then
ReminderUnreceivedMail
Sub ReminderUnreceivedMail()
Dim Itms As Items
Dim srchSender As String
Dim srchSubject As String
Set Itms = GetNamespace("MAPI").GetDefaultFolder(olFolderInbox).Items
srchSender = "sender"
srchSubject = "xyz"
Set Itms = Itms.Restrict("[SenderName] = 'sender' And [Subject] = 'subject' And [SentOn] > '" & Format(Date, "yyyy-mm-dd") & "'")
If Itms.Count = 0 Then
MsgBox "No " & srchSubject & " email on " & Format(Date, "yyyy-mm-dd")
Set Itms = Nothing
Bryan
Outlook 2013 32 bit
Thank you for your help.
Bryan
Outlook 2013 32 bit
Alright I was able to use the the script that you pointed me to. But I still cannot get it to send a email, perhaps I am not setting it up correctly. This is how I currently have it.
Dim objMsg As MailItem
If Item.MessageClass <> "IPM.Appointment" Then
If Item.Categories <> "my.name@mywork.com" Then
objMsg.To = Item.Location
objMsg.Subject = Item.XYZ
objMsg.Body = Not Item.XYZ
objMsg.Send
Set objMsg = Nothing
On the meeting that is triggering the reminder, you set a category of "my.name@mywork.com" ? The subject and body lines need to contain a string - it can be values from the original message.
Replace this part:
objMsg.Send
with the call to your macro:
in your macro, add
objMsg.To = "alias @ domain.com" ' instead of putting the address in the location field of the appt.
objMsg.Subject = "No " & srchSubject & " email on " & Format(Date, "yyyy-mm-dd")
objMsg.Body = "Did not find this email message: " & srchSubject & " email on " & Format(Date, "yyyy-mm-dd")
objMsg.Send
Bryan
Outlook 2013 32 bit
Thank you so much, I will work on implamenting this.
B Outlook 2016 Auto-archive creates new folder Using Outlook 4
P [SOLVED] Auto remove [EXTERNAL] from subject Using Outlook 6
B Auto open PDF Outlook VBA and Custom Forms 0
J Auto Accept Notifications from a shared icloud calendar? Using Outlook 4
N Auto-forwarding an Email received from a specific Email address After slight modifications Using Outlook 4
