Pull an email address from body and replace reply-to address
JLII
Outlook 2013 32 bit
Hi folks,
I've searched for what I need in the forums but couldn't find anything that fit our situation. I saw the one referring to pulling an email address from the body and forwarding a template, while also changing the subject. Mine is not as hard I don't think. Sorry if I missed one that fits our needs.
Our situation - we receive email from addresses you cannot reply to. Within the email body is the address in which we are supposed to reply to. When we receive the email from specific email addresses, I want the script/rule to replace the reply-to email address with the address one from the email body. That's so when someone clicks reply, they don't have to manually copy and paste the address into the recipient field - it's done already.
The email address is always listed in the email like this:
"E-mail: anything@anything.any"
or
"Email: [whitespace] anything@anything.any"
Is editing the reply-to address possible when receiving the email? Thanks for the help. Also, I have no experience with VBA or any programming.
JL
Generally speaking, no you can't edit the reply to address - but I think you might be able to do it using Redemption.
I have a macro at Reply to a web form generated message that grabs the address out of the message body and sends an autoreply to it. This can be converted to a macro that runs when you click a button - it could be converted to run every time you click Reply, if there is something in the body or subject to filter on. Actually, if it's generated by a web form and this is the only mail you get from the web form's address, you could filter on that address.
Do something when reply is clicked shows how to capture the Reply button and do something.
JLII
Outlook 2013 32 bit
Thanks. I'll give redemption a shot.
And if I can't do it that way, I can try the others. It is a web form and it's essentially the only mail I get from the address.
JLII
Outlook 2013 32 bit
Diane, I just thought about doing it another way. What about not changing the reply-to address when I receive it. How about:
If one of my users sends to that address, it extracts the email address from the body and swaps out with the address in the T0: field? (or it could add it, if that is easier?)
Yes, that will work. If you are using a macro to automate this, it can either add to or replace the address in the To field.
M rule to change subject, pull email addresses from body, and forward with templ Using Outlook 14
D Redemption? Need rapid pull of Outlook Contacts, email + notes for VBA Using Outlook 1
J multiple email accounts, but only want to pull from two Using Outlook 1
F Outlook 2010 will not pull in my email from my provider & the font in the body of the message area is so small it can't be read unless I use a #72 Using Outlook 5
C Pull Outlook shared calendars items from Excel Outlook VBA and Custom Forms 4
C Subject Line - Pull Down (Customizeable) Menu Outlook Wishlist 1
A Pull mail without marking and processing, only by selecting it Using Outlook 1
Commodore Back/Forward toolbar buttons with pull-down history? Using Outlook 5
K Custom Content Control or field to pull specific Outlook Address Book information into Word doc? Using Outlook 1
L Getting a 'Not Responding' message in Calendar only? Won't pull up? Very frustrating. Using Outlook 1
K Need to pull Outlook '07 contact information into Word document Using Outlook 1
P How do I set up MS Outlook 2003 to automatically pull in any e-mails that are sent to me? Using Outlook 1
E Pull Data From Non-Default Calendar Outlook VBA and Custom Forms 2
D Sending email from Office 365 alias in Outlook Using Outlook 4
S Macro or plug-in to see if specific person was included in this email Outlook VBA and Custom Forms 3
S Body text of Email from invite date/time Outlook VBA and Custom Forms 8
R Outlook 2010 How do you export 2 email Accounts' 2010 Inbox Files to new computer (2019)? Using Outlook 1
L Outlook saved email templates Using Outlook 1
T The non-email functions Using Outlook 8
P Outlook 2013 Word Share doc as Email Attachment now brings up Eudora. Using Outlook 1
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
J Outlook Reply > From > Other Email Address... > Address Not Showing in Sent Items... From Email Outlook VBA and Custom Forms 0
HarvMan Hotmail - Sending email is undeliverable Using Outlook 4
S How to export urls from email to excel and check the status of the url ? New Slipstick.com Articles 6
T How can we view Blocked email addresses Using Outlook 6
