Outlook 2007 Custom Form and Toolbar Not Working
LMS
Outlook 2007
Over many years I created the new custom form for my contacts and the new toolbars at the top, and the toolbars are not showing up and the when I open the contact, it says: the custom form cannot be opened.
Can we solve this right away as the custom form and the toolbars are a major part of my organization.
And when I open the form thru the design form, it says the say the same that the custom form cannot be opened
LMS
Outlook 2007
I fixed the contact form problem, but I need the way to fix getting the toolbars I created with all the macros that I dragged to them.
LMS
Outlook 2007
The toolbars are at the top of the outlook area...not a part of the contact form.....The way I fixed the form is that when I change it, I also copy it as a Test Form so I can see if I like it. And since the Test Form was working, I published it as the name of the contact form, and it then worked on the contact form. And as to the toolbars, I export the files you gave me to use at my other computer at home, and since I export those all the time, I imported them back to the Outlook at my office and the toolbars worked.
divan Outlook 2007 - Replace email body with custom text Using Outlook 9
Z outlook 2007 - opening a contact from the search results doesn't use the custom form Using Outlook 10
M Workarounds for sharing custom Outlook 2007 forms? Using Outlook 3
D Custom Tool Bar and/or Commands do not remain when re-opening Outlook 2007 Using Outlook 3
D Outlook 2007 Custom Form - Dual Addresses and Mailing Address Using Outlook 6
B Reply to All custom action doesn't work with attachments in Outlook 2007 Using Outlook 1
S How to call a procedure from a custom command bar in Outlook 2007 Outlook VBA and Custom Forms 1
J Making custom Outlook 2007 folders emptiable like "Deleted Items" Outlook VBA and Custom Forms 1
P outlook 2007 - custom buttoms with hyperlinks to oft files Outlook VBA and Custom Forms 1
B Importing Contacts Does Not Use Defined Custom Form in Outlook 2007 Outlook VBA and Custom Forms 1
R Build custom ribbon in Outlook 2007 Outlook VBA and Custom Forms 3
J Extra text on an Outlook 2007 custom form Outlook VBA and Custom Forms 2
K Accessing contact's custom properties in a Outlook 2007 form region Outlook VBA and Custom Forms 1
S Make field searchable in custom form in outlook 2007 Outlook VBA and Custom Forms 1
J Outlook 2007 using custom form created for Outlook 2003 Outlook VBA and Custom Forms 2
B Outlook 2007 Custom Form does not display in 2003 Outlook VBA and Custom Forms 3
