Creating templates with predefined subject and CC
CMG73
Outlook 2013 32 bit
Hi all,
I am after some advice regarding creating templates, I followed instructions found on a Microsoft guide.
I wrote the new mail, put a contact in the CC and subject line then saved as HTML and also tried the same saving it as a template.
When I try to use the template I saved, the details from both the CC and the subject lines is in the main message body, not in the CC and subject line where I expected?
Can anybody shed any light as to why this is happening, or what I may have done wrong please?
I am using Outlook 2013 but the templates will be used by colleagues using Outlook 2010.
Thanks in anticipation of your suggestions,
Chris
E Creating email templates for organizational use Using Outlook 0
R Creating a user defined function Outlook VBA and Custom Forms 3
O How to prevent CC from showing when creating a new mail? Using Outlook 1
N Creating a button or link to a form in the Organizational Forms Library Outlook VBA and Custom Forms 3
B Creating an email with the list of tasks Outlook VBA and Custom Forms 0
L Creating drafts when I thought I was sending Using Outlook 1
R Would creating a new profile cause Outlook to download all the old mails from the server? Using Outlook 1
A Creating Progress Bar or Status Bar Update Outlook VBA and Custom Forms 0
T Outlook creating a folder named: "Unwanted" Using Outlook 3
Liza Creating a rule in outlook to filter messages Using Outlook 0
S Creating Email - Selecting Pre-Defined Text Using Outlook 2
M Creating Outlook Appointments from Excel Cells Outlook VBA and Custom Forms 1
N Creating New Profile Using Outlook 0
M creating email from contact file = 3 emails in To field Using Outlook 3
P Recover / Extract Rules from standalone PST file creating RWZ file Using Outlook 2
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
I Creating meeting invite with disabled tentative button Outlook VBA and Custom Forms 5
D Creating custom view with VBA Outlook VBA and Custom Forms 2
J Outlook creating unwanted rule on its own Using Outlook 1
R Creating a Room Mailbox with Exchange Online Outlook VBA and Custom Forms 0
A Creating a rule on “Deleted items” folder Using Outlook 1
G Creating Contact Sub Folders Using Outlook 2
Rupert Dragwater creating gmail account in Outlook 2013 Using Outlook 7
nathandavies Creating a Select Case for a directory of folders Outlook VBA and Custom Forms 1
2 creating custom stationery Using Outlook 2
A Help creating macro for conditional formatting settings Using Outlook 8
Fozzie Bear Creating Custom Meeting Form Outlook VBA and Custom Forms 6
U Creating a (This computer only) folder within an IMAP account directory Using Outlook 1
A Creating archive rule on the clients by script/ Outlook VBA and Custom Forms 3
J Creating a URL from a message body excerpt before forwarding Using Outlook 2
A Creating rule to create week folder and transfer mail using alert Using Outlook 3
J Creating an "isolated" shared calendar in Outlook Outlook VBA and Custom Forms 1
L Creating a Task from Email and Attaching Original Email Outlook VBA and Custom Forms 6
S Creating custom rule to move if "NAME" is in body but ignore the phrase "Hi NAME" in the search Using Outlook 2
witzker Outlook bug when creating a user defined contact form? Using Outlook 1
G Creating an Outlook Rule using Internet Header time Using Outlook 1
Wotme Creating a Outlook task in Excel Using Outlook 7
V Need to add some text in subject while creating new mails - NEED VB CODINGS Using Outlook 4
G Questions on creating Outlook forms Using Outlook 0
P Creating custom contact forms Using Outlook 2
K Outlook 2010 creating extremely large PST files for IMAP accounts Using Outlook 3
J Troubleshooting Creating New Outlook Account Using Outlook 1
