Best utility for repairing PST files?
x509
I have several PST files of > 2 GB. I need to run scanpst against these files 3-4 times to get them to be error-free. As soon as I run Outlook, they all develop problems again. Is there a third-party utility that can fix them in just one pass, and really fix them so errors don't crop up again as soon as I run Outlook?
x509
x509
Probably not... you first need to figure out why is corrupting so frequently.sync utilities or other programs that access the pst is a common cause.
This page has the repair products.
http://www.slipstick.com/problems/pst-repair/repair-a-damaged-personal-folders-pst-file/
Thank you for your prompt response. I appreciate that. In fact, I don't use any programs other than Outlook itself to "edit" the PST files.
Looking at the repair products, there is a wide range in price. Are they all equally effective? How can I evaluate that?
Again, thank you for your response.
The ones in the tools in the spotlight section are all good - they each have a trial, so you can test it and see if it finds the missing mail. Start with the least expensive and see if it works.
Rupert Dragwater What is the best way to back up pst Using Outlook 4
Diane Poremsky The Best Outlook Store Add-ins Contest New Slipstick.com Articles 0
D a suggestion ...sent with the best intentions Using Outlook 1
M How best to track OUTGOING referrals? BCM (Business Contact Manager) 2
M best duplicate contact remover? Using Outlook 6
G what is the best way to organize outlook contacts Using Outlook 1
D What would be the best strategy? Using Outlook 3
J Best way to move form old to new, larger pst? Using Outlook 2
M Best way to move outlook? Using Outlook 1
R Best way to share outlook calendar with 10 laptops Using Outlook 9
Horsepower Email best practice Using Outlook 3
N Outlook 2010, Categories, best way to filter contacts? Using Outlook 5
F Best Non MS Exchange 2010 book for beginners? Exchange Server Administration 7
S CAS/MBX reboot best practices. Exchange Server Administration 7
I Best Practice for Large Messages NDRs? Exchange Server Administration 4
L best rule/macro to send emails from many people/orgs to same folder Using Outlook 3
R Any "Best Practices" for a test/developer Exchange 2010 server? Exchange Server Administration 2
C Best way to effectively back up Outlook Calendar (and save Categories) and Email as well???? Using Outlook 6
R Best practices for creating "Equipment" mailbox resources? Using Outlook 1
D Exchange Best Practice for DEV/TEST/PROD Exchange Server Administration 2
M Exchange 2010: What to monitor - best practices Exchange Server Administration 4
K Best case scenerio to reduce disk space usage Exchange Server Administration 5
B Best way to get a pick-list on a form? Outlook VBA and Custom Forms 1
M Best way to distribute VBA project Outlook VBA and Custom Forms 4
T Is Explorer.FolderSwitch the best event for hiding commandbarbutton? Outlook VBA and Custom Forms 5
A Recommend add-on or utility enabling quick Google search within Outlook Using Outlook 7
S What is a good utility to backup pst files for executives who have laptops. Backup changes only. Using Outlook 1
