IMAP - Sent Folder not sticking
jacobacci
Hi all
I have been annoyed by the following behaviour of outlook for several years.
My mail provider uses "SentMail" as the default place for sent messages, when I use webmail.
If I set "save sent items in the following folder on the server" to "SentMail" in my IMAP account, it may stick for a few days, but then it reverts to "Sent Items". "Sent Items" is a folder that my mobile phone uses and that was created on the mail provider's server as I was doing mail with my mobile phone.
Is there any way, I can make the "SentMail" folder stick.
Addendum: on some of my PCs, the "SentMail" folder does indeed stick, on some it reverts to "Sent Items" after a few days.
Thanks a lot and regards
It should stick... Which version of outlook? Does it seem like outlook is rebuilding the data file? Make sure all windows updates are installed then reboot. Set the sent folder in outlook and reboot. See if that fixes it.
Sent from my iPhone using Tapatalk
P Outlook Keeps Synchronizing IMAP "Sent Mail" Folder Using Outlook 0
G Macro to move sent items from local folder to IMAP folder Using Outlook 4
B Can't see Sent Items folder in OL 2010 Imap Using Outlook 1
J Save emails in the IMAP sent folder Using Outlook 2
M IMAP: Attachment column gone from sent folder. Using Outlook 4
D Sending mail from an IMAP account does not store sent mail on the correct folder Using Outlook 1
A Outlook 2013 IMAP using Google Mail App not syching Sent Mail Using Outlook 3
V Outlook 2010 IMAP Sent Items some items appear in Outlook Data File Using Outlook 3
A Outlook 2007 - single exchange Sent items, duplicate IMAP sent items? Using Outlook 2
M aoutlook 2010 sent from is not using default imap Using Outlook 1
P IMAP Sent Items with Attachment Using Outlook 3
B how to add my own imap email account with full calendar privileges to exchange/outlook to avoid invites being sent 'on behalf of' my exchang Using Outlook 2
M Outlook 2007/iMap - Sent messages appear in inbox. Using Outlook 4
P Outlook 2010 with IMAP: Location of Sent items with attachment Using Outlook 3
V Scheduled backup of imap account Using Outlook 7
O How to recover rules after switch from POP3 to IMAP Using Outlook 2
I IMAP - are emails dynamically fetched from server as required? Using Outlook 2
Mark Foley Color Categories on IMAP mail lost when installing new Windows 7 workstation Using Outlook 12
CWM030 Outlook 2016 with imap emails keep Resurrecting themselves? Using Outlook 5
CWM030 Archiving ON the imap server Using Outlook 3
Y Outlook not displaying all imap emails Using Outlook 5
Y IMAP errors with Outlook 2016 Using Outlook 2
Z Can't delete IMAP folder Using Outlook 2
GaryW88 2016 Archiving IMAP keeping mail on Gmail Server Using Outlook 1
M cannot change delivery folders with IMAP accounts Using Outlook 0
E 365 Outlook changed from POP3 to IMAP,all contacts lost Using Outlook 3
O POP3 vs iMAP? Using Outlook 1
B How to 'really' delete IMAP emails? Using Outlook 6
K IMAP Server Wants to alert you to the following: cannpt rename system folder Using Outlook 1
Diane Poremsky Setting up an Outlook.com IMAP account New Slipstick.com Articles 0
M 10 Imap gmail accounts into OL2016-32b want 1 calendar Using Outlook 3
Liz Schneider PST from Outlook 2013 is now IMAP folders in 2016 Using Outlook 10
L Gmail POP, Android IMAP, Outlook 2013 setup close Using Outlook 5
B IMAP folders don't update when Outlook 365 opens Using Outlook 0
