Creating custom view with VBA
DanTheMan
Hi all.
I have created a custom view that I now need to share with 30+ users.
I am hoping this can be done using VBA to save me from re-creating individually.
I'm new to VBA in outlook and am completely lost without the recorder.
Ideally I would like code that does the following.
Current folder>
  • add user-defined fields
  • allow in cell editing
  • remove unwanted default fields
  • save view
I would need three field types adding as follows
Type: Text
Format: Text
Type: Date/Time
Format: Best Fit
Type: Formula
Formula: [Received]
Any help would be very much appreciated.
Many thanks,
Dan.
Calvin
Exchange Server 2010
In the past I've done this by copying the view in an empty PST. Then I've attached the PST to each user to copy the views. Not so fast, but better than recreate the views every time. I don't know if it's your case, I hope it helps. If you are dealing with Exchange mailbox maybe exfolders could help too.
good luck
2 creating custom stationery Using Outlook 2
Fozzie Bear Creating Custom Meeting Form Outlook VBA and Custom Forms 6
S Creating custom rule to move if "NAME" is in body but ignore the phrase "Hi NAME" in the search Using Outlook 2
P Creating custom contact forms Using Outlook 2
F Creating Meeting Request Custom form and distribute it to domain user HELP!!! Using Outlook 0
L Creating Custom Rule to Forward emails to a BCC Using Outlook 1
A Help creating custom Contacts form - what type is 'Email' control? Outlook VBA and Custom Forms 1
R Creating a user defined function Outlook VBA and Custom Forms 3
O How to prevent CC from showing when creating a new mail? Using Outlook 1
N Creating a button or link to a form in the Organizational Forms Library Outlook VBA and Custom Forms 3
B Creating an email with the list of tasks Outlook VBA and Custom Forms 0
L Creating drafts when I thought I was sending Using Outlook 1
R Would creating a new profile cause Outlook to download all the old mails from the server? Using Outlook 1
A Creating Progress Bar or Status Bar Update Outlook VBA and Custom Forms 0
T Outlook creating a folder named: "Unwanted" Using Outlook 3
Liza Creating a rule in outlook to filter messages Using Outlook 0
S Creating Email - Selecting Pre-Defined Text Using Outlook 2
M Creating Outlook Appointments from Excel Cells Outlook VBA and Custom Forms 1
N Creating New Profile Using Outlook 0
M creating email from contact file = 3 emails in To field Using Outlook 3
P Recover / Extract Rules from standalone PST file creating RWZ file Using Outlook 2
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
I Creating meeting invite with disabled tentative button Outlook VBA and Custom Forms 5
E Creating email templates for organizational use Using Outlook 0
J Outlook creating unwanted rule on its own Using Outlook 1
R Creating a Room Mailbox with Exchange Online Outlook VBA and Custom Forms 0
A Creating a rule on “Deleted items” folder Using Outlook 1
CMG73 Creating templates with predefined subject and CC Using Outlook 1
G Creating Contact Sub Folders Using Outlook 2
Rupert Dragwater creating gmail account in Outlook 2013 Using Outlook 7
nathandavies Creating a Select Case for a directory of folders Outlook VBA and Custom Forms 1
A Help creating macro for conditional formatting settings Using Outlook 8
U Creating a (This computer only) folder within an IMAP account directory Using Outlook 1
A Creating archive rule on the clients by script/ Outlook VBA and Custom Forms 3
J Creating a URL from a message body excerpt before forwarding Using Outlook 2
A Creating rule to create week folder and transfer mail using alert Using Outlook 3
J Creating an "isolated" shared calendar in Outlook Outlook VBA and Custom Forms 1
L Creating a Task from Email and Attaching Original Email Outlook VBA and Custom Forms 6
witzker Outlook bug when creating a user defined contact form? Using Outlook 1
G Creating an Outlook Rule using Internet Header time Using Outlook 1
Wotme Creating a Outlook task in Excel Using Outlook 7
