Saving All Messages to the Hard Drive Using VBA
paspuggie48
Hi Forum
I posted a comment and question on the following link to Diane Poremsky >> http://www.slipstick.com/developer/saving-messages-to-the-hard-drive-using-vba/
Checking this morning though, it is not there anymore. So I will post it again here.
I adore the coding Diane has provided, however I just wanted to know how to re-code it so that the folder (or sub-folder) the email is in is part of the filename. Currently the .msg is saved (or exported) with a prefix of the date and time.
Below is the coding
Sub SaveAllEmails_ProcessAllSubFolders()
Dim StrSavePath As String
Dim i As Long
Dim j As Long
Dim n As Long
Dim StrSubject As String
Dim StrName As String
Dim StrFile As String
Dim StrReceived As String
Dim StrFolder As String
Dim StrSaveFolder As String
Dim StrFolderPath As String
Dim iNameSpace As NameSpace
Dim myOlApp As Outlook.Application
Dim SubFolder As MAPIFolder
Dim mItem As MailItem
Dim FSO As Object
Dim ChosenFolder As Object
Dim Folders As New Collection
Dim EntryID As New Collection
Dim StoreID As New Collection
Set FSO = CreateObject("Scripting.FileSystemObject")
Set myOlApp = Outlook.Application
Set iNameSpace = myOlApp.GetNamespace("MAPI")
Set ChosenFolder = iNameSpace.PickFolder
If ChosenFolder Is Nothing Then
GoTo ExitSub:
BrowseForFolder StrSavePath
Call GetFolder(Folders, EntryID, StoreID, ChosenFolder)
For i = 1 To Folders.Count
StrFolder = StripIllegalChar(Folders(i))
n = InStr(3, StrFolder, "\") + 1
StrFolder = Mid(StrFolder, n, 256)
StrFolderPath = StrSavePath & "\" & StrFolder & "\"
StrSaveFolder = Left(StrFolderPath, Len(StrFolderPath) - 1) & "\"
If Not FSO.FolderExists(StrFolderPath) Then
FSO.CreateFolder (StrFolderPath)
Set SubFolder = myOlApp.Session.GetFolderFromID(EntryID(i), StoreID(i))
For j = 1 To SubFolder.Items.Count
Set mItem = SubFolder.Items(j)
StrReceived = Format(mItem.ReceivedTime, "YYYYMMDD-hhmm")
StrSubject = mItem.Subject
StrName = StripIllegalChar(StrSubject)
StrFile = StrSaveFolder & StrReceived & "_" & StrName & ".msg"
StrFile = Left(StrFile, 256)
mItem.SaveAs StrFile, 3
Next j
On Error GoTo 0
Next i
ExitSub:
Function StripIllegalChar(StrInput)
Dim RegX As Object
Set RegX = CreateObject("vbscript.regexp")
RegX.Pattern = "[\" & Chr(34) & "\!\@\#\$\%\^\&\*\(\)\=\+\|\[\]\{\}\`\'\;\:\<\>\?\/\,]"
RegX.IgnoreCase = True
RegX.Global = True
StripIllegalChar = RegX.Replace(StrInput, "")
ExitFunction:
Set RegX = Nothing
End Function
Sub GetFolder(Folders As Collection, EntryID As Collection, StoreID As Collection, Fld As MAPIFolder)
Folders.Add Fld.FolderPath
EntryID.Add Fld.EntryID
StoreID.Add Fld.StoreID
For Each SubFolder In Fld.Folders
GetFolder Folders, EntryID, StoreID, SubFolder
Next SubFolder
ExitSub:
Set SubFolder = Nothing
Function BrowseForFolder(StrSavePath As String, Optional OpenAt As String) As String
Dim objShell As Object
Dim objFolder ' As Folder Dim enviro
Set objShell = CreateObject("Shell.Application")
Set objFolder = objShell.BrowseForFolder(0, "Please choose a folder", 0, enviro & "\\Engineering\Projects\Emails\")
StrSavePath = objFolder.self.Path
On Error GoTo 0
ExitFunction:
Set objShell = Nothing
End Function
Many thanks
Paspuggie48
Michael Bauer
See where the file name is built by using the strFile variable. The item's folder properties are available via Subfolder.Name or Subfolder.FolderPath
paspuggie48
Hi Michael
Forgive my ignorance, I'm pretty useless with VBA coding
So, the line code will be this??
StrFile = Subfolder.Name & Subfolder.FolderPath & StrSaveFolder & StrReceived & "_" & StrName & ".msg"
paspuggie48
Actually, looking at it I don't think it's as easy at that lol
Michael Bauer
Actually it's very easy. Have you ever seen that the first part of a full file name is the file name itself and then the second part is its directory? No. Certainly you want to write strSaveFolder first, then add some or all of the other parts to it. The last part, of course, must always be the file extension ('.msg' in this case).
C Saving Emails as Messages Problems with Access Data Collection et Outlook VBA and Custom Forms 1
D Outlook 2016 Outlook not saving Sent Items Using Outlook 4
B Saving items under a folder Using Outlook 3
V Saving attachment from outlook in My Documents Outlook VBA and Custom Forms 14
I Dialog called up multiple times when saving emails from macro Outlook VBA and Custom Forms 2
T Saving all email to file folder in Windows Using Outlook 2
C Saving Outlook attachments and links to attachments with VBA Outlook VBA and Custom Forms 2
Kevin H Remotely saving emails Using Outlook 1
R Outlook 2010 Modify Style "Do not check spelling or grammar" not saving Outlook VBA and Custom Forms 0
R Outlook Office 365 not saving addresses Using Outlook 0
S Editing an email with notes and saving it for record using Macro Outlook VBA and Custom Forms 3
J Outlook 2013 crashes saving VBA & clicking tools | digital signature Outlook VBA and Custom Forms 1
bifjamod Saving sent email to specific folder based on category with wildcard Outlook VBA and Custom Forms 1
N Saving .msg as sent item on send Outlook VBA and Custom Forms 1
erichamion Changes to meeting body not properly saving Outlook VBA and Custom Forms 4
A ItemAdd on Imap Folder get endless loop after saving item Using Outlook 5
T From Field Blank when saving to folder other than Sent items Using Outlook 2
L Outlook DST (Daylight Saving Time) problem Using Outlook 0
F Using Outlook 2007 as an IMAP Mail Station Without Saving Data Locally Using Outlook 2
E Saving Changes To Edited E-Mail Received Message Using Outlook 0
D File Lock issue when saving message from Outlook to new folder Using Outlook 1
D Remove extension while saving attachments Using Outlook 1
K Printing & Saving Outlook Contacts Using Outlook 3
S Not saving attachments in the Sent Folder Using Outlook 2
D Saving outlook emails in html and attachments Using Outlook 4
W Default Saving a message as text Using Outlook 2
R Outlook 2007 QAT buttons not saving Using Outlook 2
C Exchange 2003 - Outlook 2003 - Calendar entries saving over each other Using Outlook 2
J Saving Published Outlook Form as msg Using Outlook 1
B How to choose which contacts folder to use when saving contacts? Using Outlook 1
J Saving Incoming & Outgoing Outlook 2010 Email Locally with IMAP Using Outlook 2
F Saving Imap Drafts Using Outlook 1
J saving contact info in specific address books Using Outlook 0
R Saving Contacts Using Outlook 1
V Saving Multiple Network Passwords Using Outlook 0
