Exchange 2003 EDB corrupt
bertramtanner33
Outlook 2013 32 bit
i have customer recently where their Exchange 2003 edb file get corrupted.
now we plan to re-create new EDB file to exchange and link back to users account.
is the step just need to create a new storage group, which will also will create new edb file..?
after i create new edb/mailbox store, how can i link back to my existing user account...?
As long as you didn't touch the AD and only the database is corrupt, creating a new db and moving the mailboxes to it should work. (I think!)
Export mail from outlook to a pst before doing anything because the new database will be empty and it will cause outlook to empty the ost file. You'll need to import the pst into the new mailbox.
labeebshahidi
But still, you don’t need to fright, since you can restore the damaged/corrupt Priv1.edb file with a manual method [ link removed ]
1. First of all you need to initiate the Exchange information store and then write down all of the errors.
2. Now halt Exchange information store and then from the ‘Bin’ folder, run the commands given below:
C:\exchsrvr\bin>eseutil /mh ..\mdbdata\priv1.edb"
3. You need to now authenticate the ‘State’ line in the output. Also, make sure that all the files are steady. In case, you discover any of the files incompatible, carry out a soft recovery process. And, to execute such recovery process, you just need to move to the folder where the log files along with the database are placed. After performing this, just make sure to run the subsequent at the command prompt:
C:\Program Files\exchsrvr\MDBDATA>"C:\Program Files\exchsrvr\BIN\eseutil" /r E00
4. Once again, it is vital for you to make sure the steadiness of both the public and private information store.
5. If the files are steady, then skip the next step.
If the databases are found to be inconsistent, then it is significant for you to carry out a hard repair. To perform this, run the commands given below:
C:\Program Files\exchsrvr\MDBDATA>"C:\Program Files\exchsrvr\BIN\eseutil" /p priv1.edb
6. From Mbdata folder, eliminate the log files now which is very crucial.
7. Eliminate the 'Temp.edb' file. and '.chk' file.
8. You need to now mount the databases and then, dismount them immediately.
9. At last, you need to discontinue the ESS(Exchange information store ) and then you should defragment both private and public store DBs. To do the same, run the following commands:
For Pub.edb:
C:\Program Files\exchsrvr\BIN>eseutil /d
C:\Program Files\exchsrvr\MDBDATA\pub1.edb
For Priv.edb:
C:\Program Files\exchsrvr\MDBDATA\priv1.edb
10. Now, run the 'Isinteg.exe' utility just to make sure that each database is steady.
C:\Program Files\exchsrvr\BIN>isinteg -s (servername) -fix -test alltests
11. Lastly, restart the Exchange information store to recover the corrupt PRIV, PRIV1, Pub, and Pub1 Exchange Database Files.
sageflynn
Outlook 2013 32 bit
[link to spam deleted]
Please stop posting links on other sites are full of links to spammy software sites. Those links will be removed. If you can't post helpful information, then please don't post anything at all. I don't want to lock this thread but will if the spamming does not stop.
dimitrigigot
Older version
As I know the same issue was resolved about a year ago over there [link to spam on TechNet removed]
Not, it wasn't solved. That thread attracted spammers posting their commercial solutions - and there is a good chance it was a thread planted by the spammer whose reply was marked the answer.
A Exchange 2003 how to stop accepting EHLO and AUTH commands Exchange Server Administration 2
A Rename resource Exchange 2003 Using Outlook 2
R Exchange 2003 to 2013 mail Exchange Server Administration 4
C Exchange 2003 - Outlook 2003 - Calendar entries saving over each other Using Outlook 2
T Exchange 2003, NDR, DNS problems Exchange Server Administration 3
K clear categories on Exchange 2003 & Outlook 2003 Exchange Server Administration 1
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
T Outlook 2010/Exchange 2003: Meeting Organizer doesn't show Using Outlook 1
O Exchange 2003 displaying HTML emails as having attachments Exchange Server Administration 7
S How to leave e-mail on Exchange 2003 server? Exchange Server Administration 1
J Problems starting Information Store Server in Exchange 2003 Exchange Server Administration 13
J I use Windows XP with Microsoft Outlook 2003 and I cannot get int the Microsoft Exchange server. Using Outlook 1
B Move mailbox from Exchange 2003 to 2010 Exchange Server Administration 2
S New Outlook 2003 Clients with Existing Exchange 2010 error's Exchange Server Administration 6
K on outlook 2003, how do I set up an out of office reply if I do not use the exchange server Using Outlook 2
V Uninstall ONLY Exchange 2010 but leave Exchange 2003 server in place - Public Folders Question Exchange Server Administration 5
S exchange 2003 org to exchange 2010 org Exchange Server Administration 2
T Outlook 2003 thinks I'm connected to and exchange server. I'm not. How do I reset Using Outlook 1
H Unable to remove the last exchange 2003 server in the organization Exchange Server Administration 2
M Inbox is not syncing correctly between OWA and Windows 7 Client with Exchange 2003 Using Outlook 4
A OWA redirection in exchange 2010 and 2003 Exchange Server Administration 1
H Exchange 2003 to 2010 Transition, Public Folders Exchange Server Administration 2
K exchange 2010 OWA and exchange 2003 coexist Exchange Server Administration 1
C Outlook 2003 (or Exchange 2003): Automatically coptying someone on outbound email Using Outlook 2
C Mail folder permissions Exchange 2003/Outlook 2003 Using Outlook 1
M Outlook Mail Format Options - Grayed out 2003 office/outlook in exchange 2007 mail organisation. Using Outlook 3
A I have purchased a replacement computer and installed Outlook 2010. My server is a 2003 small business exchange server. How can I access the calenda Using Outlook 1
M Exchange 2010 Outlook Web App via Exchange 2003 Front End Server Exchange Server Administration 1
J Exchange server 2003 to 2010 Exchange Server Administration 1
L Exchange 2003 to 2010 Migration - Public Folder Replication Failed - Busy/Free Issue Exchange Server Administration 8
D Outlook 2003 is getting an error when trying to open an exchange 2010 mailbox Exchange Server Administration 5
B Entourage and Exchange 2003 SP2 Using Outlook 1
D Unable to search contacts in Outlook 2003 - Exchange 2010 Using Outlook 2
I Win 2003 AD Exchange 2003 upgrade Exchange Server Administration 6
D Users migrated from exchange 2003 cannot manage Distribution lists from Outlook Exchange Server Administration 7
J Understanding Exchange 2010 <-> Exchange 2003 Connectors....help... Exchange Server Administration 4
W Outlook 2010 Free/Busy Data not updated\viewable - Exchange 2003 SP2 Using Outlook 2
D Exchange 2003 to Exchange 2010 mail stuck in Exchange 2003 Local Delivery Queue Exchange Server Administration 10
S garbage mail recieved from Exchange 2010 HUB to Exchange 2003 user. Exchange Server Administration 2
I Copying mailboxes from Exchange 2003 to Exchange 2010 Exchange Server Administration 3
