copy contents from outlook to excell - please help.
joflo
Outlook 2013 32 bit
Hi All,
I'm very green with all this vba coding but ive managed to cobble some script together after reading a lot on this forum.
I have some questions.
1. is it possible to enter the current date and time in one of the case pattern elements?
(so that after it fills up all the relevant columns it enters a date stamp in the last column eg "F")
2. is it possible that if the pattern returns a null reading it will use a default text string ie. "no data"
3. how do I gather the information from the email information ie received date, sender, etc.
thanks in advance, loving all the information.
#######code#######
Option Explicit
Sub ACKtoExcel(olItem As Outlook.MailItem)
'Dim olItem As Outlook.MailItem
Dim xlApp As Object
Dim xlWB As Object
Dim xlSheet As Object
Dim vText, vText2, vText3, vText4, vText5 As Variant
Dim sText As String
Dim rCount As Long
Dim bXStarted As Boolean
Dim enviro As String
Dim strPath As String
Dim Reg1 As Object
Dim M1 As Object
Dim M As Object
Dim i As Long
Dim strCell As String
'the path of the workbook
strPath = enviro & "\Documents\Test123456.xlsx"
Set xlApp = GetObject(, "Excel.Application")
If Err <> 0 Then
Application.StatusBar = "Please wait while Excel source is opened ... "
bXStarted = True
On Error GoTo 0
'Open the workbook to input the data
Set xlWB = xlApp.Workbooks.Open(strPath)
Set xlSheet = xlWB.Sheets("Sheet2")
' use this line if your using and active view
'Set olItem = Application.ActiveExplorer().Selection(1)
'Find the next empty line of the worksheet
rCount = xlSheet.Range("B" & xlSheet.Rows.Count).End(xlUp).Row
rCount = rCount + 1
sText = olItem.Body
Set Reg1 = CreateObject("VBScript.RegExp")
For i = 1 To 6
With Reg1
Select Case i
Case 1
.Pattern = "(Incident Number\s*[:](.*))\n"
.Global = False
strCell = ("B")
Case 2
.Pattern = "(Engineer\s*Assigned\s*[:](.*))\n"
.Global = False
strCell = ("C")
Case 3
.Pattern = "(ETA\s*[:](.*))\n"
.Global = False
strCell = ("D")
Case 4
.Pattern = "(Part Assigned\s*[:](.*))\n"
.Global = False
strCell = ("E")
Case 5
.Pattern = "(Serial number\s*[:](.*))\n"
.Global = False
strCell = ("F")
Case 6
.Pattern = "(Part\s*to\s*site\s*via\s*[:](.*))\n"
.Global = False
strCell = ("G")
If Reg1.Test(sText) Then
' each "(\w*)" and the "(\d)" are assigned a vText variable
Set M1 = Reg1.Execute(sText)
For Each M In M1
vText = Trim(M.SubMatches(1))
'vText2 = Trim(M.SubMatches(2))
'vText3 = Trim(M.SubMatches(3))
xlSheet.Range(strCell & rCount) = vText
'xlSheet.Range(strCell & rCount) = vText2
'xlSheet.Range(strCell & rCount) = vText3
Next i
xlWB.Close 1
If bXStarted Then
xlApp.Quit
Set M = Nothing
Set M1 = Nothing
Set Reg1 = Nothing
Set xlApp = Nothing
Set xlWB = Nothing
Set xlSheet = Nothing
1. Yes - use Date for the date only or Now for the current date and time.
2. Yes, if you use an if statement something like this:
if vText = "" then
vText = "no data"
end if
3. use field names
olItem.receivedtime
olItem.sendername
olItem.subject
etc. You can get the field names from the VBA Help (F2 when in the VBA editor)
joflo
Outlook 2013 32 bit
thanks for the advice.
Ive tried to put this into the code but I am not making any progress.
sorry im not very good at this.
Replace the section that begins and ends with the first and last lines - Next i rolls through the case statements - then when you are done, it grabs the fields from the email.
 For Each M In M1
If vText = "" Then
vText = "No Data"
Next i
xlSheet.Range("H" & rCount) = Date
xlSheet.Range("I" & rCount) = olItem.ReceivedTime
xlSheet.Range("J" & rCount) = olItem.SenderName
xlSheet.Range("K" & rCount) = olItem.SenderEmailAddress
xlWB.Close 1
joflo
Outlook 2013 32 bit
When you put it like that, it almost seems obvious...
I cannot thank you enough.
Diane Poremsky Copy New Appointments to Another Calendar using VBA New Slipstick.com Articles 0
Diane Poremsky Use a macro to copy data in Outlook email to Excel workbook New Slipstick.com Articles 0
Q Why can't I copy image with embedded hyperlink from email to Word Using Outlook 0
I How to make a copy of a task Using Outlook 8
F copy data in Custom Field to other folder Outlook VBA and Custom Forms 2
A Outlook: copy & paste Outlook VBA and Custom Forms 9
L Copy email body fields to excel Using Outlook 0
C How to copy same text header to multiple emails with custom text column Using Outlook 10
T Macro to find contacts by category and copy them to another folder Outlook VBA and Custom Forms 15
A Macro to Copy Data from Outlook to Excel Spreadsheet Using Outlook 2
D How to copy yahoo email folders to hard drive Using Outlook 2
