Search and In-Place Archiving
Joe McDonald
It's unclear what the search capabilities and limitations are for Exchange 2013 In-Place Archiving. Specifically:
1. When you use Outlook 2010 Instant Search, does it automatically search BOTH the non-archived (main) and archived folder, such as the Inbox?
2. If Outlook is in online (NOT cached) mode, Exchange 2013 limits Instant Search to 250 results even if "Improve search speed by limiting the number of results shown" is unchecked (off). How does this impact In-Place Archiving?
J search doesn't find anything Using Outlook 1
C Search not accurate, but not indexing Using Outlook 9
H Outlook 2019 intermittent search results Using Outlook 0
H Search Email Header for Content Type Outlook VBA and Custom Forms 1
P Posts in Folder No Longer Group by Conversation Column After Search Using Outlook 0
O Advanced search - can I use booleans Using Outlook 3
M Something went wrong and your search couldn't be completed Using Outlook 1
L New Location for the Search Bar Using Outlook 6
King Mustard Sort search groups by amount of items? Using Outlook 1
T Search for incoming e-mails for a specified time range Using Outlook 1
R Search/Jump to a folder by typing its name Outlook VBA and Custom Forms 1
M Sent mail not showing in Sent Items folder; but they can be found with Search Using Outlook 3
A Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc Using Outlook 12
W Search Incomplete Outlook 2016 Using Outlook 5
R outlook address book search broken Using Outlook 2
R What's supposed to appear when just clicking into the search field? Using Outlook 7
B Instant search with special characters Using Outlook 1
A Search folder refresh Outlook VBA and Custom Forms 3
