convert .pst to .eml, how is it possible?
joshuaparker
Outlook 2013 64 bit
Exchange Server 2013
Guys,
I need to perform .pst conversion to .eml format.
Does anyone helpful resources or tools for such conversion?
I looked for a lot of different sources, but didnt find something helpful.
thank you
On the chance that this thread was not started for the sole purpose of promoting specific software, why do you need it in eml format? That can help guide the best method to use.
I have a list of conversion programs at http://www.slipstick.com/outlook/config/converting-messages-and-calendars/ - I personally prefer Address Magic - it does an excellent job.
If the mail can be uploaded to a server, you can download it using Windows Live Essentials mail client.
EML is just a text format, so you could use VBA to save the message and header as a text file with the eml extension.
C convert an .ost to .pst Using Outlook 3
D The way to convert ost to pst Using Outlook 2
Diane Poremsky Convert an Offline File (.ost) to a Personal File (.pst) New Slipstick.com Articles 0
S How to do I convert OST file to PST? Exchange Server Administration 3
R Convert Access table to pst Using Outlook 1
D Outlook contacts no in address book - 2002 pst file convert to 2007 pst file? Using Outlook 0
M Convert Subject Line to Internet Header version of Subject Outlook VBA and Custom Forms 10
P How do I convert outlook “to-do” items to “tasks” Outlook VBA and Custom Forms 1
sneaky30 convert text to date Outlook VBA and Custom Forms 1
M convert/import a customized record into the default "Account" record BCM (Business Contact Manager) 0
V Check/convert to emailaddresses Outlook VBA and Custom Forms 11
L Convert Distribution List of Contacts to Single Contacts Using Outlook 6
G Is there any way to convert outlook 2003 to outlook 2007 Using Outlook 5
A Outlook 2003: convert all RTF emails to HTML Outlook VBA and Custom Forms 1
J How to convert BCM contacts to normal Outlook contacts BUT... BCM (Business Contact Manager) 2
G Tasks - convert email to task & attach email Outlook VBA and Custom Forms 6
A Re: Convert Oportunity to Project? BCM (Business Contact Manager) 3
B convert VBA code to Add-in Outlook VBA and Custom Forms 1
Q How tough is it to convert VBA to Addin Outlook VBA and Custom Forms 1
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
K Export Folder to PST Outlook VBA and Custom Forms 2
HarvMan Outlook 365 PST Report Using Outlook 1
P PST file is getting huge under POP 3 Using Outlook 2
J Export Zimbra to Outlook PST Using Outlook.com accounts in Outlook 1
S What's in a PST file? Using Outlook 1
