modify vba to run it as script rule
Omar
I'm trying to modify the following code to use it as rule Script but for some reason I can not figure it out how to modify the following line
For Each Item In Application.ActiveExplorer.Selection
here is the full code
Option Explicit
Public Sub UpdateReport(Item As Outlook.MailItem)
  Dim xlApp As Excel.Application
  Dim xlWB As Excel.Workbook
  Dim xlSheet As Excel.Worksheet
  Dim vText As Variant
  Dim sText As String
  Dim vItem As Variant
  Dim i As Long
  Dim rCount As Long
  Dim bXStarted As Boolean
  Dim FileName As String
  Dim FilePath As String '// SaveAs CSV File Path
  Dim sPath As String '// .CSV File Path
  '// the path of the workbook
  sPath = "C:\temp\temp.csv"
  Set xlApp = GetObject(, "Excel.Application")
  If Err <> 0 Then
  Application.StatusBar = "Please wait while Excel source is opened ... "
  bXStarted = True
'  On Error GoTo 0
  '// Open the workbook to input the data
  Set xlWB = xlApp.Workbooks.Open(sPath)
  Set xlSheet = xlWB.Sheets("Oracle Order")
  '// Process Mail Item in ?
  sText = Item.Body
  vText = Split(sText, Chr(13)) ' Chr(13)) carriage return
  '// Find the next empty line of the worksheet
  rCount = xlSheet.Range("B" & xlSheet.Rows.Count).End(xlUp).Row
  rCount = rCount + 1
  '// Check each line of text in the message body
  For i = UBound(vText) To 0 Step -1
  '// Customer
  If InStr(1, vText(i), "Customer") > 0 Then
  vItem = Split(vText(i), Chr(9)) ' Chr(9) horizontal tab
  xlSheet.Range("A" & rCount) = Trim(vItem(1))
  '// Order #
  If InStr(1, vText(i), "Order #") > 0 Then
  xlSheet.Range("B" & rCount) = Trim(vItem(1))
  '// Service Level
  If InStr(1, vText(i), "Service Level") > 0 Then
  xlSheet.Range("J" & rCount) = Trim(vItem(1))
  Next i
  FilePath = Environ("USERPROFILE") & "\Documents\Temp\"
  FileName = Sheets(1).Range("B2").Value
  xlWB.SaveAs FileName:=FilePath & FileName
  Next Item
  '// Close & SaveChanges
  xlWB.Close SaveChanges:=True
  If bXStarted Then
  xlApp.Quit
  Set xlApp = Nothing
  Set xlWB = Nothing
  Set xlSheet = Nothing
  Set Item = Nothing
You need to remove that line (obviously) because run a script only processes the newly arrived message.
"Item" in Public Sub UpdateReport(Item As Outlook.MailItem) tells outlook to refer to the newly arrived message as "Item" - it looks like you only need to remove that line and the Next Item at the end and it should work.
Omar
Diane thanks for taking the time to help me.
when I remove that line, and run test it gave me a
Rule in Error ( The Script "" doesn't exist or is invalid)
Next Item
Omar
I did Michael, here is what the code looks like now.
Option Explicit
Public Sub Test(Item As Outlook.MailItem)
    Dim sText As String
    Dim i As Long
    Dim rCount As Long
    Dim XStarted As Boolean
    If Err <> 0 Then
        XStarted = True
    On Error GoTo 0
    Set xlSheet = xlWB.Sheets("Report")
    '// Process Mail body
    sText = Item.Body
    rCount = rCount + 1
        '// Customer Name
        '// Order Number
        '// Service Level
    Next i
    FileName = xlWB.Sheets(1).Range("B2").Value
    If XStarted Then
        xlApp.Quit
    Set xlApp = Nothing
    Set xlWB = Nothing
    Set Item = Nothing
Michael Bauer
Did you maybe move the script to another module? What happens if you edit the rule, and select the rule again?
Omar
okay it is working now, I have deleted the rule and re-created. Thank you Michael & Diane.
Rolando
Mine is failing too. It only works for me manually if I name it Public Sub Test() without Option Explicit
2773
It's not going to run in a rule because you have it working on select or open messages.
You just need the reply code at the end (and the strBody of course)
Sub ReplytoMessage(Item As Outlook.MailItem)
Set myReply = Item.replyall
strbody = "whatever"
'handle plain text or html format
If Item.BodyFormat = olFormatHTML Then
    myReply.HTMLBody = strbody  & vbCrLf & myReply.HTMLBody
     myReply.Body = strbody & vbCrLf & myReply.Body
myReply.Display ' change to send after testing
S VBA to modify appointment item in additional Exchange account doesn't work Using Outlook 0
R Outlook 2010 Modify Style "Do not check spelling or grammar" not saving Outlook VBA and Custom Forms 0
Justo Horrillo It's possible to modify the behaviour of the conversation option? Using Outlook 2
S Modify account template? BCM (Business Contact Manager) 0
R Can't modify Outlook view font with IE anymore (even though IE still affects print font) Using Outlook 5
smokiibear How to modify Today Page to Include tasks from other task folders Using Outlook 1
S Modify recurring outlook invites based on form entry Using Outlook 0
C How To Open Outlook Attachment in Excel, Modify some Data, then Re-Save It Using Outlook 3
A Possible to modify people preview window? Using Outlook 1
R How to modify Outlook Select Rooms form columns Using Outlook 1
G Modify Subject line of incoming mail where I am in Cc line Using Outlook 1
N modify New mesage SEND button Outlook VBA and Custom Forms 1
R Custom Archive code -- modify my code! Outlook VBA and Custom Forms 3
C How do I grab a field property (like .value) so I can modify it via OL code? Outlook VBA and Custom Forms 4
A Script to either modify "from" address or prevent a reply being se Outlook VBA and Custom Forms 2
B Can't modify PR_CLIENT_SUBMIT_TIME? Outlook VBA and Custom Forms 1
