How can I Customize Message Header in both Reading Pane and Open Message Design?
Susan Young
Exchange Server 2010
I have an URGENT QUESTION:
Is it possible to design the Message Header in both the "Open Mail Window" and the "Reading Pane"?
I tried using "Design A Form" within Outlook BUT:
a) Many of the default controls are missing. For example: Flag, Importance, Image of Sender etc.
b) There is no option to design the Reading Pane.
Can you please help?
Is there any other way to achieve this?
Outlook version: 2010.
Exchange version: 2010
S Customize the autocolor font choices for replying/forwarding messages Outlook VBA and Custom Forms 2
A Customize meeting form. Private notices Outlook VBA and Custom Forms 3
J Customize Attachement Security Warning Using Outlook 1
M Customize Comments / Notes Section time stamp on Contact Records BCM (Business Contact Manager) 0
Diane Poremsky Customize the Outlook Toolbar, Ribbon or QAT New Slipstick.com Articles 0
M Customize CreateItemFromTemplate Macro Outlook VBA and Custom Forms 2
Ankit Agrawal Customize themes in outlook 2010 Using Outlook 1
M please customize this code Using Outlook 1
G Customize Outlook Today folder Using Outlook 0
C Anyone found a way to customize search? BCM (Business Contact Manager) 5
T Customize button image for separate Outlook forms region Outlook VBA and Custom Forms 2
R How to implement customize toolbar in outlook? Outlook VBA and Custom Forms 1
N How to add fields to customize reports in BCM? BCM (Business Contact Manager) 3
S Unable to extract text from an Outlook email message Using Outlook 2
R Outlook 2016 Message-ID oddity/inconsistency? Using Outlook 7
J Implement Keywords based on body message Outlook VBA and Custom Forms 0
C must select message to trigger safe list Using Outlook 3
A Flag Message for Follow Up after sending Outlook VBA and Custom Forms 1
C Why won't Title display in message list? Using Outlook 1
icacream content in this message could not be downloaded.... Using Outlook 2
R Warn before sending message Outlook VBA and Custom Forms 4
M Message list font changed after update Using Outlook 2
