Problems Opening Excel from Outlook
Alan McGowan
Outlook 2013 64 bit
I am trying to open an Excel spreadsheet from within Outlook using the code below. It works perfectly if Excel is already running. If Excel is not already open it seems to open Excel (as it appears in task manager) but doesn't open the spreadsheet. Any ideas?
Dim xl As Object
Dim xls As Object
Dim strxls As String
Dim intSection As Integer
Dim intTries As Integer
Dim strFullPathAndFileName As String
' Set full path and filename
strFullPathAndFileName = "C:\filemail\fm_settings.xlsm"
intSection = 1 ''attempting GetObject...
' Try to refer to running instance of Excel
Set xl = GetObject(, "Excel.Application")
xl.Visible = True
' If Excel wasn't running...
If xl Is Nothing Then
' start Excel
Set xl = CreateObject("Excel.Application")
xl.Visible = True
MsgBox "Can't start Excel!", vbExclamation
On Error GoTo 0
intSection = 0 ''resume normal error handling
' Open text file
Set xls = xl.Workbooks.Open(strFullPathAndFileName)
Set xl = Nothing
Alan McGowan
Outlook 2013 64 bit
Sorted. I had to add
xl.Visible = True
after the line of code
Can
Exchange Server 2010
I want to open 2 excels and copy some rows from one to another. I used this code to open but ı could not manage to open 2 excels. Please help.
Sub excel1(item As Outlook.MailItem)
Dim xlApp As Object
Dim sourceWB
Dim sourceWS
With xlApp
.Visible = True
.EnableEvents = True
strfile = "\\Tcjumbo\cno-rapor\Rapor_098\W-40\CQI_CS_Drop_Hucre_Detay_W40.xlsx" 'Put your file path.
Set sourceWB = xlApp.workbooks.Open(strfile, , False, , , , , , , True)
Set sourceWH = sourceWB.worksheets("Sheet1")
sourceWB.Activate
C problems Using Outlook 1
