Need help with finding/updating task
tu2011
Outlook 2013 32 bit
Hi!
I'm new to Outlook VBA macros and I'm wondering if someone here would be kind enough to help me out.
My Goal: What I'm trying to do is have a macro that looks at the email's subject heading for a keyword, "SR" when I hit Send button. If it exists, prompt me with a message to create a Task (or automatically create it) with the same subject heading as the email's and a due date 4-5 days from now. If a task with the same subject heading already exist, then either delete it and create a new one or update it with the new date.
The Problem I Currently Have: My script some what works. It prompts and creates a new Task based on the email's subject heading. However, it creates a new task for every time I send the email with the same subject heading (i.e. emails of the same thread). So I end up with multiple tasks getting created. I tried implementing different search functions but I don't know what the proper command to us and how to get it to work. If you can show me how to do so or if you can think of a better way to do this, I would be very much appreciated.
Here is what I have so far.
Private Sub MyMailItem_Send(Cancel As Boolean)
    Dim olApp   As Outlook.Application
    Dim olTask  As Outlook.TaskItem
    Dim oFolder As Outlook.MAPIFolder
    Set oFolder = Application.Session.GetDefaultFolder(olFolderTasks)
    Set colItems = oFolder.Items
    Dim strSubject As String
    Dim objSch As Outlook.Search
    If InStr(MyMailItem.Subject, "Mentor Graphics SR") > 0 Then
        If MsgBox("Create A Follow Up Task?", vbYesNo) = vbYes Then
            Set olApp = Application
            strSubject = "Follow Up: " & MyMailItem.To & " : About :" & MyMailItem.Subject
            Dim strFilter As String
            strFilter = "urn:schemas:httpmail:subject = " & strSubject
            Const strScope As String = "'Tasks'"
            Set objSch = olApp.AdvancedSearch(strScope, strFilter)
            If objSch <> Null Then
                olTask.Delete
                MsgBox ("Tasks Found")
                Set olTask = olApp.CreateItem(olTaskItem)
                olTask.Subject = "Follow Up: " & MyMailItem.To & " : About :" & MyMailItem.Subject
                olTask.Body = olTask.Body & MyMailItem.Body & vbCrLf
                olTask.Categories = Replace(MyMailItem.To, ",", "-")
                olTask.DueDate = Date + 4
                olTask.Status = olTaskWaiting
                olTask.Display
                olTask.Save
                olTask.Close (olSave)
Michael Bauer
Calling AdvancedSearch doesn' return the search result, you need to subscribe to the AdvancedSearchComplete event instead.
private sub Application_AdvancedSearchComplete(byval SearchObject as Search)
 'here check Search.Results
end sub
private sub mymailitem_send(cancel as boolean)
  application.advancedsearch scope, filter
end sub
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
K Excel Import Option: Need Help Updating Existing Records BCM (Business Contact Manager) 0
K Need help concerning emails linking to BCM. BCM (Business Contact Manager) 0
J Need help with installation of BCM in Outlook2013 BCM (Business Contact Manager) 5
F Outlook 2010 - Need help with a custom field. Using Outlook 3
L Need help getting calendar/contacts/tasks/notes back! Using Outlook 3
P Need help/Gmail accounts show separately/Outlook 2013 Using Outlook 0
J Need Help Extracting Email Content into Excel Specifically the Attachment Name Using Outlook 3
A Need Help with BCM2010 Sharing on outlook 2013 Scenario! BCM (Business Contact Manager) 1
W I Need help with vb.net and outlook 2010 Using Outlook 2
A My move to MS is not going too well: Need Help !!! Using Outlook 14
M Need help with combo boxes in messages! Using Outlook 10
D Need help understanding which pst-file to use! Using Outlook 0
U Need a help please Outlook 2007 crashing Using Outlook 2
Z Need Help Outlook 2007 inbox and address book view Using Outlook 2
B Need help adding a background color to the compact list items in Month view. Calendar Printing Assistant 1
B Need help adding an image next to the Month Name in the header. Calendar Printing Assistant 1
B Ok - a complicated one - but really need help (auto formatting) Using Outlook 9
B OUTLOOK 2000, Need Help ! Outlook Wishlist 1
P To Use BCM or not...I need help BCM (Business Contact Manager) 1
T Need help making RULE to prepend email SUBJECT Using Outlook 3
V Need help on configuring Outook 2003 Rules and Alerts... Using Outlook 2
X business owner in dire need of help outlook is not syncin my contacts! Using Outlook.com accounts in Outlook 2
D Need email verification for international emails, help? BCM (Business Contact Manager) 2
S MAcro - Need help in getting the recipients in to filed / cc field toput in an array Outlook VBA and Custom Forms 4
K Need help Publishing a new Task form! Outlook VBA and Custom Forms 1
A Need help in creating a mass emailing plugin Outlook VBA and Custom Forms 1
T need help w/ sending an e-mail -- outlook 2007 addin Outlook VBA and Custom Forms 2
A Wishlist Arthur workman I need the community's assistance thank you Using Outlook 4
A from Arthur to anyone I need your expertise assistance Using Outlook.com accounts in Outlook 7
