Upgrade BCM System from 2010 to 2013
Outlook 2013 32 bit
Exchange Server 2010
I have read through the docs and what I could find with bingle, but I am still confused about the process.
I have a client with SBS 2010 hosting the shared BCM 2010 database.
I am adding a few new desktops which will run Win10 and office 2013 and BCM 2013.
I have a few desktops which are running Win7 and office 2010 and BCM 2010 and they will be upgraded to Win10 with office 2013 and BCM 2013.
I understand the process to upgrade the existing machines and the new machines I can clean install office 2013 and BCM 2013.
What I can not find explicit directions for is how to upgrade the remote database to work with BCM 2013. I assume I need to do this first?
Can you shed some light on this please,
Thankx,
HandyAndy
PS Thank You for all you do for the community!
U BCM upgrade help BCM (Business Contact Manager) 0
E How to restore BCM Database after upgrade from Vista to Win7? BCM (Business Contact Manager) 1
B Upgrade 2003 BCM to 2007 BCM BCM (Business Contact Manager) 3
J BCM no longer loads sqlserver after SP2 upgrade BCM (Business Contact Manager) 2
T upgrade from outlook.com to Outlook Using Outlook 2
T How do I upgrade from outlook.com to Outlook? Using Outlook 5
M re-Attaching PSTs after upgrade to 2016 Using Outlook 0
M Upgrade in Progress. Your mailbox is currently being optimized as part of upgrade to Outlook 2010 Using Outlook 9
E Upgrade Issues - Office/Outlook 2007 to 2010 Using Outlook 0
Diane Poremsky How to Upgrade to Color Categories New Slipstick.com Articles 0
P Outlook 2013 search broken after upgrade from 2010 Using Outlook 0
W Outlook 2013 - 2nd acct stopped receiving email after Win 8.1 upgrade Using Outlook 3
F Which upgrade should I go for and how do I do it please? Using Outlook 2
H Outlook 2010 unable to send iCloud account e-mail after iOS 7 upgrade Using Outlook 12
B Two Inboxes after upgrade, how to merge? Using Outlook 4
L Outlook 2002-2013 upgrade Using Outlook 3
Horsepower Upgrade advice needed Using Outlook 3
T Outlook 2010 keeps asking password after upgrade Exchange Server Administration 1
B Upgrade 2003 to 2010 and max pst file size of 2GB Using Outlook 2
J Upgrade from 2003 to 2007 Outlook VBA and Custom Forms 14
S Upgrade Outlook 2007 to outlook with Buisiness Contact m|Manger BCM (Business Contact Manager) 2
B Upgrade to 2007, Action stopped working Outlook VBA and Custom Forms 3
A Upgrade to 2007, lost 'Accounts' info BCM (Business Contact Manager) 1
T Custom form created in 2003 won't print since upgrade to 2007 Outlook VBA and Custom Forms 1
T Custom form created in 2003 won't print since upgrade to 2007 Outlook VBA and Custom Forms 13
