Copy and paste body and subject and send multiple emails
VB NB
Outlook 2007
I want to copy the body and subject of a current email and send it to different distribution list.
Here is what I found in this forum : I made some changes to adapt to my project.
Sub Old_reply()
Dim objApp
Dim objInsp
Dim Mail As Outlook.MailItem
Set objApp = GetObject("", "Outlook.Application")
If objApp Is Nothing Then
Set objApp = Application.CreateObject("Outlook.Application")
Set objInsp = objApp.ActiveInspector.CurrentItem
If TypeName(objInsp) = "Nothing" Then
MsgBox "No inspector window found"
Set Mail = Outlook.CreateItem(olMailItem)
With Mail
.To = "mymail@mymail.com"
.BCC = "List1"
.Subject = objInsp.Subject
.Body = objInsp.Body
.Send
Set Mail = Nothing
Set Mail2 = Outlook.CreateItem(olMailItem)
With Mail2
.BCC = "List2"
.Send
Set Mail2 = Nothing
Problem : macro doesn't copy the subject line.
Can you help me ?
Thanks a lot in advance
Vince
VB NB
Outlook 2007
I checked the code again and it seems to work now.
So ... problem resolved.
As an FYI, because Outlook is open (you are working in it) you don't need to check for it.
Set objApp = Outlook.Application
If you were creating a message from Excel or Word, you'd use get/create object.
F I cannot highlight text in Microsoft Outlook 2010 e-mails, and copy/paste to the body of another e-m Using Outlook 3
A Outlook: copy & paste Outlook VBA and Custom Forms 9
R Copy/paste mailing address Outlook 2013 Using Outlook 6
D Open attached CSV, copy newdata and paste it to database CSV Outlook VBA and Custom Forms 2
O Copy email content and paste into new Word Document using a different font Using Outlook 1
L "sometimes" cant send mail, we have to copy and paste the message and resend? Using Outlook 2
S I'm not able to copy and paste on outlook. Using Outlook 1
M Outlook 2007 Copy-Paste problems Using Outlook 6
J cannot copy and paste while in list view in-cell editing Using Outlook 1
R how to copy a list of email contacts and paste them only as names (not names + email address) Using Outlook 12
K Copy Entire Email Content - Paste into new Task Outlook VBA and Custom Forms 2
K How to copy Contact Item to Clipboard and Paste as "VCF Link? Outlook VBA and Custom Forms 4
S Using copy paste to grab email addresses from the TO: address fiel Using Outlook 14
Diane Poremsky Copy New Appointments to Another Calendar using VBA New Slipstick.com Articles 0
Diane Poremsky Use a macro to copy data in Outlook email to Excel workbook New Slipstick.com Articles 0
