RS box added in Favorites disappears
Kristine
Hi All,
Has anybody seen this issue wherein RS box added in Favorites disappears. User have 15-20 RS boxes added in Outlook and she is putting 5-6 of them under the Favorites. working limit to the number of RS mailboxes that can be attached and still function normally.
Here are the things that we have tried and has not worked.
> Repair OST
> Recreate Profile
> Repair Office
> Reinstall Office
> We did some searching online and found other similar issues reported. The information seems to be stored in Exchange server and locally cached in Outlook.xml file located:
C:\Users\username\AppData\Roaming\Microsoft\Outlook . We tried to rename the .xml file and the issue seems to be only
Any suggestions/advice? Thanks!
[DOUBLEPOST=1440607802][/DOUBLEPOST]**Is there a working limit to the number of RS mailboxes that can be attached and still function normally.
Kristine
Thanks for the response Diane. We'll check on that and let you know how it goes.
Kristine
UPDATE:
We tried to cached the folders and also check on the registry key for the Namespace (HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\14.0\Outlook\Namespaces) but it does not exist for the user. Both of which still didn’t resolve the issue, though we were able to identify which shared folders are having the issue. It is only the shared folders that the user owns and are auto-mapping via auto-discover which are randomly removed from the favorites. Any ideas?
The affected folders are the ones I suspected to be the cause... it usually works to enable cache for shared folders. If you right click on a folder and choose open in new window, are the missing folders on the favorites list in the new window?
Kristine
The cache has already been enabled for the shared folders and outlook has been restarted multiple times. Also, the issue seems to be intermittent wherein it seems to work for a couple of days then the issue comes back.
A GetSelectNamesDialog Pre-fill search box Outlook VBA and Custom Forms 12
P Custom Outlook form_Validations in combo box Outlook VBA and Custom Forms 0
K Sharedmail box Outlook VBA and Custom Forms 4
Diane Poremsky Outlook Suggestion Box at Uservoice New Slipstick.com Articles 0
D Emails do not appear in Sent box! Using Outlook 4
rohit I want to Populate Popup box while sending any email with attachment. Outlook VBA and Custom Forms 4
rohit I want to Populate Popup box while sending any email with attachment Using Outlook 1
Ross Garvey Dialogue box opens as I exit Using Outlook 2
P BCM 2013 Contacts Form Drop Down Box Bug BCM (Business Contact Manager) 1
G Enter Network Password box pops up every few seconds Using Outlook 2
S Outlook form - Combo box for deciding who to send form to Using Outlook 1
V In Box Issues Using Outlook 1
S Custom yes/no message box. Using Outlook 0
L Auto-set followup/reminder popup box for ALL sent emails. Using Outlook 0
P VBA for Dialog Box when sending Email Using Outlook 8
M Send receive Progress Box Using Outlook 4
M How do I link a drop down box to a percent complete box Using Outlook 4
B In Box Empty Using Outlook 5
M details with the combo box Exchange Server Administration 3
L Combo Box Using Outlook 157
M Preventing conversation from moving to the top of the message box? Using Outlook 7
A Dialogue box 'Do you want to save this file?' Save or Cancel From: C:\Users\Ad Using Outlook 5
S OL 2007 user typing. into file box results in .htm.msg Using Outlook 5
K Need to get OOO messages more than once for the same email box Using Outlook 2
O Search Address Books Box Using Outlook 1
O Sent mail from ( Yahoo ) appear on hotmail sent box Using Outlook 2
I Notification/Popup Box not showing on right side Using Outlook 1
O "Replied" messages not in "sent" box, but are appearing in my "inbox" from me Using Outlook 1
