Macro in an excel for outlook.
sri
Outlook 2013 64 bit
Hi All,
Nice to see this wonderful website & blog on outlook. I am ok with excel macro, but a total newbie for outlook macros.
This is my first post. Looking help from the experts to guide me on this.
I am looking for a macro in excel for outlook.
I need this macro to search for 2 specific email Id's & if those email Id's have an word document attached, then it need's to write the following in this excel.
From the mail, the senders email ID, Date & the subject Line.
From the attachment (The macro needs to open the word document) & then write
Project ID (Alphanumerical), Project (Alphanumerical or sometimes only text) &Sub Total (currency numbers, like $1234)
It is for office 2013 version & all the mails are in inbox.
The word document is usually in the RTF extension.
Happy weekend.
Michael Bauer
Application.Session.GetDefaultFolder(olFolderInbox).Items gives you access to all inbox items. Application in this case points to Outlook, so if you use it in Excel, you need to use another variable for that.
If "email Id" means the email address of the sender, you can use the Find function, which is explained in the VBA help file. If an item is found, loop through it's Attachments collection, and check the extensions of the attached files. If one is rtf, call the Attachment.SaveAsFile method, then open that file in Word and look for the project id etc. by using the functions of the Word object model (Range.Find, which is explained in the Word VBA help file).
sri
Outlook 2013 64 bit
Thanks, Michael, will try it out.
Diane Poremsky Use a macro to copy data in Outlook email to Excel workbook New Slipstick.com Articles 0
W macro to export outlook emails to excel Outlook VBA and Custom Forms 6
J Outlook Macro to Update Sharepoint Excel File Using Outlook 1
A Outlook Macro Causing Excel Error Outlook VBA and Custom Forms 0
A Macro to Copy Data from Outlook to Excel Spreadsheet Using Outlook 2
P Outlook Macro sends information to Excel Using Outlook 1
nathandavies Email Details to Excel & Save as .MSG on one macro - combination of 2 macros Outlook VBA and Custom Forms 3
W How to build a macro that interacts with and uses information from an Excel sh Using Outlook 1
C OL Sub through or by Excel Macro Call Outlook VBA and Custom Forms 1
S Macro or plug-in to see if specific person was included in this email Outlook VBA and Custom Forms 3
