Trouble using keyboard shortcut for color categories in Outlook 2016
Mont
I use Windows 7 but just added Outlook 2016 as a stand-alone feature. My GMail email is IMAP-configured, and I need to be able to categorize my emails according to color. I used to be able to do this when I had Outlook 2007, but the function no longer works in Outlook 2016.
Since IMAP supposedly does not allow for color categories, I read on slipstick about the workaround using keyboard shortcuts... Where assigning a shortcut to a color can trick accounts using IMAP to display a color: http://www.slipstick.com/outlook/outlook-categories-flags-and-imap-accounts/
However, while I am able to apply the shortcut and create new colors on emails I click on in my archived folders, the shortcut function still does not work in my GMail account. What could be the problem?
Many thanks for your help!
Michael Bauer
The macro is already available. You only need to paste it as described.
K Trouble using SaveAs Outlook VBA and Custom Forms 3
G Trouble with Office 365/2016 Using Outlook 3
M Trouble downloading Outlook on an Android phone Using Outlook 4
B Trouble Starting Outlook 2010 after Crash Using Outlook 3
U Trouble migrating Contacts (2002) to People (2013) Using Outlook 3
K New to BCM - trouble importing contacts & accounts BCM (Business Contact Manager) 3
B Trying to get old emails from a not working computer but having trouble. Using Outlook 6
M Trouble Importing folders from Outlook 2007 to Outlook 2013 Using Outlook 12
B Trouble Locating Tools Menu since There's No Standard Toolbar in Office 2010 Using Outlook 1
T Outlook 2007 - trouble with alphabetizing when titles are used (ie - Mr.) Using Outlook 0
M Outlook 2010 stuck in Work Offline mode; trouble sending email Using Outlook 1
B Trouble Adding @Outlook.com Email Accounts Using Outlook 3
K Trouble converting the ANSI PST to a Unicode PST Using Outlook 4
U Trouble for sharing Calendar Using Outlook 3
S Trouble setting up Outlook Connector to sync with windows live Using Outlook.com accounts in Outlook 3
N Trouble importing calender information from iPhone into OutLook 2010 Using Outlook 1
J TROUBLE SENDING EMAIL FROM OUTLOOK, NO PROBLEM RECIEVING WHEN WORKING FROM OUT OF TOWN Using Outlook 1
T Trouble with creating database BCM (Business Contact Manager) 1
M having trouble importing excel data into outlook contacts BCM (Business Contact Manager) 1
M trouble connection to remote database BCM (Business Contact Manager) 1
