how to remove icons on right hand side outlook 2013
colin1960
Outlook 2013 64 bit
on the right hand side of outlook when you are in the inbox - I get icons that move email up - down-delete- etc - where the To Do Bar would g0 - these icons I cannot remove.
I need to get the real estate back - could someone please tell me how to get rid of these icons on the right hand side of the screen... please see attached jpg.
Colin
colin1960
Outlook 2013 64 bit
Diane... you are AWESOME... and providing me the link to show me how to reset was what I needed.
Thank you so much for the quick reply and the correct solution...
Everyone Diane is a 10 plus+++
Thanks again...
Colin
C-S-R Manage Add-ins (Remove Wunderlist) Using Outlook 3
O Remove duplicates within two accounts Using Outlook 2
D How to remove a folder, option grayed out Using Outlook 4
B Remove Subject Residual Outlook VBA and Custom Forms 3
R Chancing / remove “ something ” in the subject, online archive Outlook VBA and Custom Forms 8
Morgan Fowler Remove Signature Using Outlook 1
M VBA to remove deferred delivery on a MeetingItem Outlook VBA and Custom Forms 2
J Remove extra line above signature in reply Outlook VBA and Custom Forms 5
Diane Poremsky How to Remove RSS Support from Outlook Using Outlook 0
Diane Poremsky Remove Attachments From Messages Using Outlook 0
Diane Poremsky Remove Office 2013 Update Banner Using Outlook 0
O Remove duplicate mail items Outlook VBA and Custom Forms 6
Diane Poremsky Remove a password from an Outlook *.pst File Using Outlook 3
L Fake reminder apperaring (not in calendar) - how to remove? Using Outlook 5
J Your IMAP server wants to alert you to the following: cannot remove system folder Using Outlook 3
K Remove Manage APPS button for users Exchange Server Administration 1
P Remove name and parenthses from email Using Outlook 1
G Outlook calendar entry corrupted. Constant pop up when you open outlook. Unable to delete or remove. Using Outlook 2
Diane Poremsky How to remove the primary account from Outlook 2010/2013 Using Outlook 0
Diane Poremsky Remove an Address from Reply All Using Outlook 0
Diane Poremsky Remove Outlook apps from Outlook Using Outlook 0
S How to remove forms from Organizational forms library Outlook VBA and Custom Forms 2
2 Task has a strike through but is not complete - how to remove? Using Outlook 1
W URGENT Cancel and remove imported pop3 mails Using Outlook 6
T How to remove annoying Big Blue Type at beginning of my messages Using Outlook 2
H Cannot remove unwanted fields from form Outlook VBA and Custom Forms 9
T How to remove "automatically delete messages form this sender"? Using Outlook 1
M How to remove duplicate history items BCM (Business Contact Manager) 7
