Advanced recurrence problem
skylark53
Outlook 2013 32 bit
Exchange Server 2013
I have an event that recurs daily at noon for 5 days at the start of October
I want this recurring, 5-day sequence to recur annually on the first 5 days of October. Is this possible?
skylark53
Outlook 2013 32 bit
Excellent, Diane; thank you. The second one won't suit, as we need a daily reminder (every day for 5 days). But the first possibility had not occurred to me and I shall use this.
O Advanced search - can I use booleans Using Outlook 3
H "Advanced find: column for full folder path? Using Outlook 1
Andrew Hawkins "Advanced Find" Using Outlook 1
P Outlook Advanced Find Using Outlook 0
S Advanced Find text field limits Using Outlook 2
C O2010: Using Advanced Find to locate exact queries Using Outlook 3
N Outlook 2010 crippled Advanced Find, now what? Using Outlook 3
H Outlook 2010 Advanced Find - Menu items missing Using Outlook 1
D Outlook 2010 - Advanced Find - No Status Bar = No Item Count Using Outlook 2
J How to filter by address fragment (e.g. "@domain.com") with advanced find? Using Outlook 2
P Open Advanced Search Dialog Outlook VBA and Custom Forms 1
A Outlook Advanced Search Problems...returns with an Error: Argument Outlook VBA and Custom Forms 1
J Advanced outlook trick: help needed! Outlook VBA and Custom Forms 3
S Programmatically bring up Advanced Find for contacts? Outlook VBA and Custom Forms 1
T Outlook 2007 Indexing Options and Advanced Search options disabled Using Outlook 5
G Arggh, weakness of reminder for every Task recurrence Using Outlook 0
A Custom form not showing when recurrence is set for a meeting Using Outlook 0
C Find all deleted recurrence appointments Outlook VBA and Custom Forms 4
M Clear custom date field after recurrence Outlook VBA and Custom Forms 0
M Recurrence and custom fields Outlook VBA and Custom Forms 0
Commander1 Task Recurrence Settings Using Outlook 3
Jennifer Murphy Regenerate recurrence not working Using Outlook 3
Commodore Recurrence for N times, and one gets cancelled Using Outlook 3
A Appointment recurrence reset to 'end after 25 occurrences' Using Outlook 1
A Reminder for an overdue task with recurrence is disabled without user’ Outlook Wishlist 4
J Outlook Appointment recurrence setting Outlook VBA and Custom Forms 4
H Creating yearly recurrence appointment Outlook VBA and Custom Forms 5
H Creating recurrence appointment Outlook VBA and Custom Forms 2
W Change Start Time in Recurrence of an Appointment Outlook VBA and Custom Forms 2
W How do I calculate the next recurrence date? Outlook VBA and Custom Forms 1
V Get selected option in recurrence range group Outlook VBA and Custom Forms 4
