Two Sync Issues folders
Commodore
Outlook 2013 32 bit
On one IMAP account in Outlook 2013 I have two local Sync Issues folders (with corresponding Local Failures subfolders) - Sync Issues and Sync Issues1. Deleting them is disabled. Is there any way to remove it (other than, I suppose, removing and re-creating the account in Outlook)?
I'm surprised you can't delete one of the two... but you don't need to remove the account, only the data file.... or use MFCMAPI to delete one folder. I'd probably restart outlook using the resetfolders switch then use mfcmapi to delete sync issues1.
If you use rules, export them then right click on the top level folder (usually the email address) and choose open file location to open windows explorer to the right location. Close outlook and delete the file. Outlook will need to download everything.
Commodore
Outlook 2013 32 bit
Thanks, deleting .OST did the trick. However, it created another issue - how can I rename the "header" of the mailbox as displayed on the left? It was "name@email.something", but now it's "IMAP: name@email.something" (probably because a long time ago I actually had this naming convention...).
Commodore
Outlook 2013 32 bit
Yes, I had "FROM" or "IMAP" prefixes added, but that was before you could actually rearrange them in the folder list. So now even the re-created OST was "IMAP email@address.domain.ost" - which probably came from the profile, because the account properties was already named correctly as email@address.domain. I had to first add a few letters, and then changed it back, so that the correct name was then reflected in the folder list.
S Outlook.com Sync working, Sync to Android has issues Using Outlook.com accounts in Outlook 1
Diane Poremsky Outlook and iCloud Sync Issues New Slipstick.com Articles 0
S Outlook 2016 Sync issues with outlook.com Using Outlook 0
mwh1962 Sync issues with Windows 8.1 phone Using Outlook 2
D Sync issues Using Outlook 1
R Outlook 2013 IMAP Sync Issues Using Outlook 1
O Other BCM - Outlook sync issues BCM (Business Contact Manager) 1
R Thousand of sync issues on Outlook clients with Exchange 2010 Exchange Server Administration 5
J __Outlook sync issues Using Outlook 6
P Constant "Sync Issues"; Outlook 2010, Exchange 2010 Using Outlook 2
J I'm getting a lot of sync issues. I've got Outlook 2007 and using Outlook Connector to download my Using Outlook 2
P Constant Outlook Sync Issues After Migrating Mailbox 2003->2010 Using Outlook 18
S How do I turn off logging in 'Sync Issues' folder in Outlook 2007? Using Outlook 2
O Outlook 2016 - two addressbooks - how to sync and which one is in use? Using Outlook.com accounts in Outlook 1
Peter R Hawkes Can I sync VBAProject.otm? Outlook VBA and Custom Forms 1
M Mobile notifications and sync in Outlook.com Using Outlook.com accounts in Outlook 2
GregS No contacts sync from Outlook 2016 to Windows Phone Using Outlook 0
