Save in folder other than Sent when replying with Quick Steps
Snowdog850
Outlook 2016 64 bit
I implemented Inbox Zero a while ago. It's working great, but I'm having a lot of trouble getting to Sent Items zero. I checked the option that says "When replying to a message that is not in the Inbox, save the reply in the same folder". That works fine to keep me organized and things out of Sent Items. However, it means that I have to move the message into the right folder before replying. So I get an e-mail, move it to the proper folder, then open the folder, go to the message, and hit Reply.
I thought that Quick Steps might help. I created a Quick Step with two steps. The first moves the current message into my Customers folder. The second step does Reply. I thought that since I had already moved the message, that the Reply would go into the Customers folder. But it does not. It goes to Sent Items. So this doesn't really save me any time, because I then have to go into Sent Items and move the e-mail.
Any way to do this? I can't filter based on anything because any e-mail could end up in my Customers folder. It might be from a Customer, or it might be from someone in my organization referencing a customer problem.
If I could assign a category to the reply with a Quick Step, then I could create a Rule to put it into the proper folder, but I can't assign a category.
How about rules to move everything as they arrive and use a search folder to show you all of the unread mail together in one folder? Replies will go into the folder with the original and both the inbox and sent folder will be empty.
Snowdog850
Outlook 2016 64 bit
My problem is that usually need to make a manual decision on each e-mail that comes in. For example, my co-worker might send me an e-mail that is about the current development project, customer support, or the latest trade by the Cubs. When I open the e-mail and read it, I know which folder it's supposed to go in, but I can't make a rule that would know ahead of time.
oh. How about using search folders to find the message easier after it was moved? The problem with using quick steps is that it replies then moves. The other option is to set the move to folder on the message, but that will be slower.
Brandon
Outlook 2013 64 bit
Just an FYI, I was chasing the answer to the exact same problem. Seems like a VBA script was the only way to go.
Just google "Save in folder other than Sent when replying with Quick Steps"
on superuser.
Diane Poremsky Choosing the Folder to Save a Sent Message In Using Outlook 0
R How do I 'Save Copy of Sent Item to Folder' for a Shared Mailbox Outlook VBA and Custom Forms 9
J Save emails in the IMAP sent folder Using Outlook 2
W Save all incomming and sent mails to folder on PC as .msg files Using Outlook 6
Diane Poremsky Save Messages and Attachments to a New Folder Using Outlook 0
L Save Mail Message to new folder created automatically Outlook VBA and Custom Forms 1
M Save selected email message as .msg file (with user to choose folder location) Outlook VBA and Custom Forms 14
nathandavies How to save emails to a specific folder on a network automatically using a macro Outlook VBA and Custom Forms 14
L Save Contact Search as a Folder 2007 Using Outlook 1
D Automatically save attachment to network folder Exchange Server Administration 1
B Task macro to save task into specific folder Outlook VBA and Custom Forms 1
B Option: Save to folder ? Using Outlook 4
S Outlook 2010: Cannot save forms templates to folder list Using Outlook 4
E Auto Save Zip File Attachment to Network Folder Outlook VBA and Custom Forms 1
Y How to save a custom form in a specified folder? Outlook VBA and Custom Forms 2
S save attachment with date & time mentioned inside the file Outlook VBA and Custom Forms 0
S automate save the .xlxs file to share Network Using Outlook 1
R VBA | Chosing path to save file Outlook VBA and Custom Forms 1
