Reading Pane has disappeared
El_Diabolo
Hi All,
Outlook 2010 was working fine, but at some point yesterday when I opened it the Reading Pane had disappeared. I then set it appear to the right, which it did. I closed and re-opened Outlook and it had gone again. Also, the Reset View button is greyed out, which suggests to me that the view without the Reading Pane has become the default view. I have tried Run-Outlook /cleanviews, but to no avail, probably confirming my suspicion about the default view. I tried disabling the Add-Ins one at a time, but that didn't help either. I then opened Outlook in Safe Mode, but no difference. Now I can't get out of Safe Mode. Help!!!!
Many thanks for any replies.
from Outlook 2010 runs in Safe Mode after Update - Outlook Tips
Uninstall KB3114409 or edit the registry -
open regedit -
  1. Browse to HKEY_LOCAL_MACHINE\Software\Microsoft\Office\14.0\Outlook\Security\
  2. Right click on Security key and choose New, and then DWORD Value.
  3. Type DisableSafeMode, and then press Enter.
  4. Right-click on DisableSafeMode, and then click Modify.
  5. In the Value data box, type 1, and then click OK.
  6. If you have 64bit Windows and 32bit Office, also add DisableSafeMode, Value: 1 to this key: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Office\14.0\Outlook\Security\
  7. Restart Outlook or reboot the computer.
Diane Poremsky Excel Files Won't Display in Reading Pane New Slipstick.com Articles 1
M Outlook 2007: how to narrow the reading pane and the composing pane Using Outlook 0
T Outgoing Messages in the Reading Pane Cannot Be Flagged in Outlook 2013 Using Outlook 6
F Outlook 2007 - Reading Pane Automatically Downloads First/Topmost Message Using Outlook 4
C Contact photos not showing in reading pane in Outlook 2013 Using Outlook 3
T Killing reading pane - "globally" Using Outlook 11
M Viewing Custom Form Fields in the Reading Pane and in Replies Using Outlook 3
R Reading Pane text appearing all the way to the right... Using Outlook 1
D Cursor in reading pane Using Outlook 5
J Outlook 2010 reading pane option - want to permanently adjust the zoom setting. Using Outlook 13
S Outlook 2010 reading pane not clearing Using Outlook 3
S Macro for Viewing mails one after the other in the Reading Pane Outlook VBA and Custom Forms 2
E CustomTaskPane in PLace of Reading Pane Outlook VBA and Custom Forms 3
T Blank Email in Reading Pane for Custom Form Outlook VBA and Custom Forms 12
C Getting reading pane horizontal instead of vertical Using Outlook 2
Y View Reading Pane for Drafts folder Using Outlook 2
V Reading/Posting in Newsgroups Using Outlook 1
A Received Date None after reading Using Outlook 2
P exchange management consoles has stoped working and yes I have read the above article and tried the troubleshooter and spent days reading and trying d Exchange Server Administration 0
M Reading .msg Messages In MS Outlook For Mac 2011 Using Outlook 1
C Change default reading font in Outlook from Times New Roman 12 point to Arial Using Outlook 2
B Reading CompressedRichText field in SQL database BCM (Business Contact Manager) 1
L Windows Instant Search Indexing not working need help reading Event Log Using Outlook 2
B Huge characters when reading some mails Using Outlook 42
A Outlook 2010 keeps closing and restarting when reading messages Using Outlook 12
R Proof Of Looping Bug in Reading Outlook Inbox From Access? Outlook VBA and Custom Forms 2
L Reading another mailbox Address Outlook VBA and Custom Forms 2
N Reading Recipients in a folder Outlook VBA and Custom Forms 1
