Outlook script to run excel data
xoomoon
Outlook 2016 64 bit
Hi guys,
I'm new to the forum and I need help with something. What I want to do is create a rule in outlook to filter incoming customers' orders to a specific folder. I have over 400 customers and I don't want to create over 400 rules to filter the emails. Is there a faster way to do this? I have a macro to create the 400 folders in Outlook already. Now, all i have to do is create a rule from each customer and filter it out to the correct folder.
For instance, if the subject is "order #123" it will filter to "order#123" folder.
If there's a script to create a folder based on the subject, that would be good too. Or, if there's a way for outlook to run the 400 data in Excel and create a rule to filter them out to specific folders from there.
L Outlook 2007 Macro to Run a Script From a Contact Form Using Outlook 41
S using script rule to save attachments on arrival Outlook 2010 Outlook VBA and Custom Forms 9
J VBS Script (macro) for word to open Outlook template. Outlook VBA and Custom Forms 2
J Email Parsing VBA Script for Outlook - NEEDED Outlook VBA and Custom Forms 7
J VBS Script: How to execute in Outlook Outlook VBA and Custom Forms 8
Hudas Outlook VBA script reverting back to previous changes Outlook VBA and Custom Forms 2
M Outlook Rule To Redirect Mail - Script to overcome lack of cc's & others Using Outlook 0
C Outlook Script Error Using Outlook 0
L Limit VBA Script to one Outlook account Using Outlook 1
S Outlook 2010, need script for rules & Warnings Using Outlook 3
C Outlook 200? - Script Export Rules Using Outlook 1
R Change Outlook 2010 Exchange server address via registry or script Using Outlook 5
G Script Error message when trying to print e-mails using Outlook Mail Using Outlook 2
B Outlook Script ( using calendar function in a form) Outlook VBA and Custom Forms 3
witzker Open Contact missing in Outlook 2019 Using Outlook 2
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
M outlook 365 trying to finish my sentences Using Outlook 0
D Outlook Address Book Using Outlook 0
V Outlook 2016 Does Outlook-2016 (64 bit) work with iCloud for Windows ? Using Outlook 4
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
V Outlook 2016 Outlook-2016 and iCloud for Windows - Problems Using Outlook 2
K Imap PC Outlook + Android phone Using Outlook 1
C All Gmails don't show in Outlook 2019 Using Outlook 3
witzker Macro to move @domain.xx of a Spammail to Blacklist in Outlook 2019 Outlook VBA and Custom Forms 6
