Note Field (Any way to do incell editing)
mrje1
Hello Everyone,
For a task, is there a way to do incell editing with the predefined note field? At this point I guess you can't, which is a bummer.
BTW, you could use a macro to pop up a dialog box to enter text then save it, but I'm not sure it will have a lot of benefit over just opening the item.
mrje1
Thank you Diane for your help and assistance. It is kind of mind boggling why you can't. Is there a way to let them know to see if we can get a fix for it?
By setting a macro for this, would that dialog box open up as soon as you click the note field cell or how would that dialog box open?
Thank you so much again.
I'd have to look into it - but you'd probably need to click a button. I don't think we can detect clicking in the Note field in the view.
mrje1
Ok, thank you. Is there a way to let Microsoft know and possibly get them to change it?
You can make a request at uservoice - but I will ask about it too. Many of my contacts are on vacation until Jan 4 so it will a while before I know their reasoning for the lock out.
Outlook 2016 for Windows: Top (0 ideas) – Got an idea? - they just moved it from the Office 365 group, so you could be the first to make a suggestion. :)
mrje1
Thank you very much Diane for your help. Much appreciated! Looking forward to see what they say. DONE! First one to add a suggestion. Never had that before. It kind of feels good! :)
U No scrolling in note field of contact record Using Outlook 1
L Contact Photo For Calendar Note Field Using Outlook 4
L Contact Photo For Calendar Note Field Using Outlook 0
L How to acess the note field in contact item Outlook VBA and Custom Forms 19
L Source Name for Appointment Note/Message field Using Outlook 0
0 Add a date stamp to the note field of a custom form Outlook VBA and Custom Forms 1
A Note field on general tab BCM (Business Contact Manager) 5
W Get a "New Note" icon onto the QAT Using Outlook 3
D IMP.Note Versus REPORt.IPM.NOte Outlook VBA and Custom Forms 3
M One Note as a mail folder Using Outlook 6
L Outlook 2007 Code for Note Fields of Appointment Using Outlook 102
L Outlook 2007 Contact Form - Note Fields Using Outlook 25
W Calendar Note Font Reverting Using Outlook 11
M Unable to search Note section in Contacts in icloud Using Outlook 7
J add note to body or notes Outlook VBA and Custom Forms 5
S Note: The GMT offset above does not reflect daylight saving time adjustments Using Outlook 12
C Automatically Insert Recipient Name from To Field Outlook VBA and Custom Forms 4
O Filter-Query Builder-Description - what field name to use? Using Outlook 4
V Checking for empty field Outlook VBA and Custom Forms 2
A new labeled phone field Using Outlook 4
V Making a Date field mandatory in outlook form Outlook VBA and Custom Forms 2
N Exporting IM Address field Using Outlook 2
