Macro that does not overwrite but add a number
snhnic
Exchange Server 2010
Below macro works fine, but when there are more selected messegas with the same attachment it overwrite. I would like that the macro writes a number to it. attachent.pdf and then attachement(1).pdf and so on or somtehing like it. Can this be done in the macro below? I dit not created it and I'm not a programmer.
Sub MoveAttachmentsToFolder()
Dim olMailItem As MailItem
Dim olAtt As Attachment
Dim intAtt As Integer
Dim strPath As String, FileName As String
If Application.ActiveExplorer.Selection.Count = 0 Then
MsgBox ("select E-mail Items")
'strPath = fnShellBrowseForFolderVB
strPath = "c:\attachment"
If Len(strPath) = 0 Then
strPath = strPath & "\"
intAtt = 0
For Each olMailItem In Application.ActiveExplorer.Selection
If olMailItem.Class = olMail Then
For Each olAtt In olMailItem.Attachments
FileName = strPath & olAtt.FileName
olAtt.SaveAsFile FileName
intAtt = intAtt + 1
MsgBox intAtt & " Attachement(s) Saved in: " & strPath
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 2
